Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Introduzione
The back cover and the battery have to be removed before the SimCard can be reached. No tools are required.
  1. Turn the phone so it is face down (keypad side is down).
    • Turn the phone so it is face down (keypad side is down).
  2. Press and hold the button located at the bottom of the phone. Slide the back of the phone downwards and away from the main body. Remove the backing and place it to the side.
    • Press and hold the button located at the bottom of the phone.
    • Slide the back of the phone downwards and away from the main body.
    • Remove the backing and place it to the side.
  3. Kit per Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Locate indentation from which battery can be removed. Place finger in indentation and lift battery up from phone's body. Remove battery from phone's body.
    • Locate indentation from which battery can be removed.
    • Place finger in indentation and lift battery up from phone's body.
    • Remove battery from phone's body.
  5. Push the SimCard towards the bottom of the phone.
    • Push the SimCard towards the bottom of the phone.
  6. Slide finger underneath top of SimCard. Lift up the SimCard and rotate the top of the SimCard so it moves toward the bottom of the phone.
    • Slide finger underneath top of SimCard.
    • Lift up the SimCard and rotate the top of the SimCard so it moves toward the bottom of the phone.
  7. Pull up on the SimCard and remove it from the back of the phone. Place the SimCard to the side.
    • Pull up on the SimCard and remove it from the back of the phone.
    • Place the SimCard to the side.
Conclusione
To insert a new SimCard, simply push the card in as shown in step 6, and snap it in place.
Reid Polstra
Membro da: 22/10/2012
1 Reputazione
7 Guide realizzate
Clemson, Team 15-5, Benson Fall 2012 Membro di Clemson, Team 15-5, Benson Fall 2012
CLEM-BENSON-F12S15G5
3 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 654
