Salta al contenuto principale
Nokia 6133 Speaker Replacement
Cosa ti serve
  1. Nokia 6133 Speaker Replacement, Battery: passo 1, immagine 1 di 2 Nokia 6133 Speaker Replacement, Battery: passo 1, immagine 2 di 2
    • Remove the back cover of your cell phone by applying slight pressure with your thumb and pushing up towards the top of the phone.
    • Lift off back cover.
  2. Nokia 6133 Speaker Replacement: passo 2, immagine 1 di 3 Nokia 6133 Speaker Replacement: passo 2, immagine 2 di 3 Nokia 6133 Speaker Replacement: passo 2, immagine 3 di 3
    • Use your index finger to first push down and then lift up the battery as shown.
    • Remove battery from cell phone.
  3. Nokia 6133 Speaker Replacement, Keypad: passo 3, immagine 1 di 2 Nokia 6133 Speaker Replacement, Keypad: passo 3, immagine 2 di 2
    • Unscrew two T5 torx screws easily visible on the back side of the cell phone
    • Screws: 7.8mm
    • Once screw are removed, the phone will separate easily into two pieces connected by a flexible wire strip.
    • Be sure to not lose or disconnect the indicated piece that the screw mounts to. It is spring loaded and is very dificult to reattach.
  4. Nokia 6133 Speaker Replacement: passo 4, immagine 1 di 3 Nokia 6133 Speaker Replacement: passo 4, immagine 2 di 3 Nokia 6133 Speaker Replacement: passo 4, immagine 3 di 3
    • Use an iPod opening tool to gently pry open the back case as indicated in the picture.
    • Work your way down the side of the phone starting from the top down to the bottom. (Use multiple prying tools if necessary)
    • REPEAT on both sides, and be careful not to stab the circuitry with the tools.
  5. Nokia 6133 Speaker Replacement: passo 5, immagine 1 di 3 Nokia 6133 Speaker Replacement: passo 5, immagine 2 di 3 Nokia 6133 Speaker Replacement: passo 5, immagine 3 di 3
    • Gently pull the phone apart and the flexible wire should detach from its connection as shown.
    • If not, lift up on the black tab within the left box in the picture.
    • With the front half of the phone, push the keypad towards the removed portion of the phone.
    • To clean, use a damp cloth with water.
  6. Nokia 6133 Speaker Replacement, Logic Board: passo 6, immagine 1 di 1
    • Use a T6 Torx Screwdriver to remove the screw located in the bottom right corner of the back panel.
    • Screw: 6.4 mm
  7. Nokia 6133 Speaker Replacement: passo 7, immagine 1 di 2 Nokia 6133 Speaker Replacement: passo 7, immagine 2 di 2
    • Lift up from the top of the logic board as shown to remove.
  8. Nokia 6133 Speaker Replacement, Speaker: passo 8, immagine 1 di 2 Nokia 6133 Speaker Replacement, Speaker: passo 8, immagine 2 di 2
    • After removing the logic board from the back of the phone, pry the speaker out from the bottom with an iPod opening tool.
    • It should pop out easily
Conclusione
Cal Poly, Team 23-82, Johann Spring 2010 Membro di Cal Poly, Team 23-82, Johann Spring 2010
CPSU-JOHANN-S10S23G82
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 2,702
