Salta al contenuto principale
Nokia 6133 External/Main LCD Replacement
Cosa ti serve
  1. Nokia 6133 External/Main LCD Replacement, Battery: passo 1, immagine 1 di 2 Nokia 6133 External/Main LCD Replacement, Battery: passo 1, immagine 2 di 2
    • Remove the back cover of your cell phone by applying slight pressure with your thumb and pushing up towards the top of the phone.
    • Lift off back cover.
  2. Nokia 6133 External/Main LCD Replacement: passo 2, immagine 1 di 3 Nokia 6133 External/Main LCD Replacement: passo 2, immagine 2 di 3 Nokia 6133 External/Main LCD Replacement: passo 2, immagine 3 di 3
    • Use your index finger to first push down and then lift up the battery as shown.
    • Remove battery from cell phone.
  3. Nokia 6133 External/Main LCD Replacement, Keypad: passo 3, immagine 1 di 2 Nokia 6133 External/Main LCD Replacement, Keypad: passo 3, immagine 2 di 2
    • Unscrew two T5 torx screws easily visible on the back side of the cell phone
    • Screws: 7.8mm
    • Once screw are removed, the phone will separate easily into two pieces connected by a flexible wire strip.
    • Be sure to not lose or disconnect the indicated piece that the screw mounts to. It is spring loaded and is very dificult to reattach.
  4. Nokia 6133 External/Main LCD Replacement: passo 4, immagine 1 di 3 Nokia 6133 External/Main LCD Replacement: passo 4, immagine 2 di 3 Nokia 6133 External/Main LCD Replacement: passo 4, immagine 3 di 3
    • Use an iPod opening tool to gently pry open the back case as indicated in the picture.
    • Work your way down the side of the phone starting from the top down to the bottom. (Use multiple prying tools if necessary)
    • REPEAT on both sides, and be careful not to stab the circuitry with the tools.
  5. Nokia 6133 External/Main LCD Replacement: passo 5, immagine 1 di 3 Nokia 6133 External/Main LCD Replacement: passo 5, immagine 2 di 3 Nokia 6133 External/Main LCD Replacement: passo 5, immagine 3 di 3
    • Gently pull the phone apart and the flexible wire should detach from its connection as shown.
    • If not, lift up on the black tab within the left box in the picture.
    • With the front half of the phone, push the keypad towards the removed portion of the phone.
    • To clean, use a damp cloth with water.
  6. Nokia 6133 External/Main LCD Replacement, External/Main LCD: passo 6, immagine 1 di 2 Nokia 6133 External/Main LCD Replacement, External/Main LCD: passo 6, immagine 2 di 2
    • Using an iPod opening tool, pry open the case that houses the LCD screens by inserting it at the bottom as shown.
    • VERY FRAGILE!! Don't press hard on either side of the LED.
    • Run the tool all along the edge between the darker front case and silver back.
    • Rather difficult to open this part, be careful not to compromise the screens.
  7. Nokia 6133 External/Main LCD Replacement: passo 7, immagine 1 di 2 Nokia 6133 External/Main LCD Replacement: passo 7, immagine 2 di 2
    • Remove the first flex-wire connection by inserting your thumbnail directly underneath the connection as shown. Will pry off easily.
    • This flex-wire connects the LCD logic board to the main logic board removed earlier.
    • Remove the two other flex-wire connections at the top and bottom of the LCD logic board. Pry up on the respective connections as shown.
    • Square LCD logic board will detach now.
  8. Nokia 6133 External/Main LCD Replacement: passo 8, immagine 1 di 3 Nokia 6133 External/Main LCD Replacement: passo 8, immagine 2 di 3 Nokia 6133 External/Main LCD Replacement: passo 8, immagine 3 di 3
    • Pry back the associated tabs using your thumbnail or an iPod opening tool by pulling them away from the LCD panel.
    • LCD can now be removed easily.
    • To clean use any multipurpose lens cleaner and a soft cloth. DO NOT get lens cleaner on any electronic component!
    • Shown:
    • LCD (Main display side)
    • LCD logic board
    • Case that holds above components and camera.
Conclusione
Will
Membro da: 04/21/10
40 Reputazione
1 Guida realizzata
Cal Poly, Team 23-82, Johann Spring 2010 Membro di Cal Poly, Team 23-82, Johann Spring 2010
CPSU-JOHANN-S10S23G82
4 Membri
5 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 4,736
