Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Introduzione
Use this guide to remove and repair the logic board.
Parti
Nessuna parte specificata.
  1. Press and hold the button at the bottom of the back side of the phone while sliding the back plate down to remove the back cover. Note: Images on the right side may be hovered over to reveal larger versions. Note: Images on the right side may be hovered over to reveal larger versions.
    • Press and hold the button at the bottom of the back side of the phone while sliding the back plate down to remove the back cover.
    • Note: Images on the right side may be hovered over to reveal larger versions.
  2. Lift up the battery from the inside of the phone.
    • Lift up the battery from the inside of the phone.
    • Make sure to lift up from the bottom of the battery as shown.
  3. Essential Electronics Toolkit
    Small Toolkit. Big Possibilities.
    Shop Toolkits
    Essential
    Electronics
    Toolkit
    Shop Toolkits
  4. Using a .208 head T-6 Screwdriver remove the two screws at the bottom of the battery cavity. Using a .208 head T-6 Screwdriver remove the two screws at the bottom of the battery cavity.
    • Using a .208 head T-6 Screwdriver remove the two screws at the bottom of the battery cavity.
  5. Use a plastic opening tool to remove the silver cover over the antenna. The covering may not pop right off.  It may require some prying in different locations around the top covering.
    • Use a plastic opening tool to remove the silver cover over the antenna.
    • The covering may not pop right off. It may require some prying in different locations around the top covering.
  6. Remove the two newly revealed .208 inch screws at the top using a T-6 screwdriver. Remove the two newly revealed .208 inch screws at the top using a T-6 screwdriver.
    • Remove the two newly revealed .208 inch screws at the top using a T-6 screwdriver.
  7. WARNING: Use extreme caution when removing and handling the logic board as it is very fragile. With caution, use a plastic prier to separate the back silver casing from the front of the phone. This may require force.
    • WARNING: Use extreme caution when removing and handling the logic board as it is very fragile.
    • With caution, use a plastic prier to separate the back silver casing from the front of the phone. This may require force.
    • Disconnect the logic board from the small orange chip.
Conclusione
Altre 2 persone hanno completato questa guida.
Alex Graebe
Membro da: 15/04/2010
1 Reputazione
2 Guide realizzate
Cal Poly, Team 23-78, Johann Spring 2010 Membro di Cal Poly, Team 23-78, Johann Spring 2010
CPSU-JOHANN-S10S23G78
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 2,574
