Salta al contenuto principale
Nokia 6102i Outside Display Screen Replacement
Cosa ti serve
  1. Nokia 6102i Outside Display Screen Replacement, Remove Inside Display Screen: passo 1, immagine 1 di 3 Nokia 6102i Outside Display Screen Replacement, Remove Inside Display Screen: passo 1, immagine 2 di 3 Nokia 6102i Outside Display Screen Replacement, Remove Inside Display Screen: passo 1, immagine 3 di 3
    • This step does not require much force.
    • Use the plastic opening tool to pry between the seam of the black phone cover which is located at the base of the screen.
  2. Nokia 6102i Outside Display Screen Replacement, Remove Phone Case Screws.: passo 2, immagine 1 di 2 Nokia 6102i Outside Display Screen Replacement, Remove Phone Case Screws.: passo 2, immagine 2 di 2
    • Have a container ready to keep track of small parts.
    • Use the t6 screwdriver to remove the two visible screws that are immediately below the screen.
  3. Nokia 6102i Outside Display Screen Replacement, Remove silver and black phone case: passo 3, immagine 1 di 2 Nokia 6102i Outside Display Screen Replacement, Remove silver and black phone case: passo 3, immagine 2 di 2
    • Keep the phone closed, and slide the Ipod tool between the the silver and black phone case. Use the tool to slide all the way around the case to release the catches.
  4. Nokia 6102i Outside Display Screen Replacement, Unplug and Remove Circuit Board: passo 4, immagine 1 di 2 Nokia 6102i Outside Display Screen Replacement, Unplug and Remove Circuit Board: passo 4, immagine 2 di 2
    • Pull out the circuit board, which will remove it completely from the case
  5. Nokia 6102i Outside Display Screen Replacement, Remove Display Screen: passo 5, immagine 1 di 3 Nokia 6102i Outside Display Screen Replacement, Remove Display Screen: passo 5, immagine 2 di 3 Nokia 6102i Outside Display Screen Replacement, Remove Display Screen: passo 5, immagine 3 di 3
    • If the metal case is not already free, simultaneously release the metal tabs on both sides of the metal casing to remove the display screen.
  6. Nokia 6102i Outside Display Screen Replacement, Disconnect Interior Display Screen from circuit board.: passo 6, immagine 1 di 2 Nokia 6102i Outside Display Screen Replacement, Disconnect Interior Display Screen from circuit board.: passo 6, immagine 2 di 2
    • Be gentle when pulling off the display screen. If pulled too hard, the orange connecting ribbon will rip.
    • Lift off the display screen and disconnect it from the circuit board.
Conclusione
Cal Poly, Team 23-78, Johann Spring 2010 Membro di Cal Poly, Team 23-78, Johann Spring 2010
CPSU-JOHANN-S10S23G78
4 Membri
5 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 2,805
