Salta al contenuto principale
Nokia 6086 Screen Replacement
Cosa ti serve
  1. Nokia 6086 Screen Replacement, Battery: passo 1, immagine 1 di 1
    • Turn off the phone.
    • Check if there is a microSD card in the slot behind the door on the side. If so, remove it by first pushing it in, then pulling it out.
    • Position the phone so that the back side is in view.
  2. Nokia 6086 Screen Replacement: passo 2, immagine 1 di 3 Nokia 6086 Screen Replacement: passo 2, immagine 2 di 3 Nokia 6086 Screen Replacement: passo 2, immagine 3 di 3
    • Remove the back battery cover.
    • Apply pressure on the cover while simultaneously sliding the cover downward.
  3. Nokia 6086 Screen Replacement: passo 3, immagine 1 di 3 Nokia 6086 Screen Replacement: passo 3, immagine 2 di 3 Nokia 6086 Screen Replacement: passo 3, immagine 3 di 3
    • Insert the iPod opening tool between the base of the phone and the phone battery.
    • Position the phone so that the battery won't fall out of the phone.
    • The battery lifts out of the phone fast and easily.
    • Carefully lift the battery out of the phone.
  4. Nokia 6086 Screen Replacement, Top Front Cover: passo 4, immagine 1 di 1
    • Close the phone.
    • Face the front cover forward.
  5. Nokia 6086 Screen Replacement: passo 5, immagine 1 di 2 Nokia 6086 Screen Replacement: passo 5, immagine 2 di 2
    • Locate the 4.5 mm notch at the top of the phone.
    • Place the iPod opening tool into the opening.
    • Slightly prop up the top section by lifting the tool.
  6. Nokia 6086 Screen Replacement: passo 6, immagine 1 di 3 Nokia 6086 Screen Replacement: passo 6, immagine 2 di 3 Nokia 6086 Screen Replacement: passo 6, immagine 3 di 3
    • Wedge the iPod opening tool between the top cover and the phone.
    • Gently lift the top cover away from the phone using the iPod opening tool.
    • This unlatches each hook that connects the top cover to the phone.
    • Repeat for both the left and the right sides of the phone.
    • Place the top cover aside once the top cover is completely disconnected from the phone.
  7. Nokia 6086 Screen Replacement, Screen: passo 7, immagine 1 di 3 Nokia 6086 Screen Replacement, Screen: passo 7, immagine 2 di 3 Nokia 6086 Screen Replacement, Screen: passo 7, immagine 3 di 3
    • Locate the four screws on the phone.
    • The top right screw is located under the black connector piece.
    • To remove the connector piece gently lift it off of its connector.
    • Take the T6 driver and remove the screws.
  8. Nokia 6086 Screen Replacement: passo 8, immagine 1 di 1
    • Carefully lift up the motherboard.
  9. Nokia 6086 Screen Replacement: passo 9, immagine 1 di 2 Nokia 6086 Screen Replacement: passo 9, immagine 2 di 2
    • Find the orange slip on the motherboard.
    • Peel back the orange slip to expose the screen.
  10. Nokia 6086 Screen Replacement: passo 10, immagine 1 di 3 Nokia 6086 Screen Replacement: passo 10, immagine 2 di 3 Nokia 6086 Screen Replacement: passo 10, immagine 3 di 3
    • Place the ipod opening tool under the screen.
    • Remove the damaged screen with the ipod opening tool.
Conclusione
Caitlin Rahm
Membro da: 04/15/10
78 Reputazione
4 Guide realizzate
Cal Poly, Team 26-30, Regan Spring 2010 Membro di Cal Poly, Team 26-30, Regan Spring 2010
CPSU-REGAN-S10S26G30
4 Membri
18 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 3,517
