Salta al contenuto principale
Nokia 6086 Keypad Replacement
Cosa ti serve
  1. Nokia 6086 Keypad Replacement, Battery: passo 1, immagine 1 di 1
    • Turn off the phone.
    • Check if there is a microSD card in the slot behind the door on the side. If so, remove it by first pushing it in, then pulling it out.
    • Position the phone so that the back side is in view.
  2. Nokia 6086 Keypad Replacement: passo 2, immagine 1 di 3 Nokia 6086 Keypad Replacement: passo 2, immagine 2 di 3 Nokia 6086 Keypad Replacement: passo 2, immagine 3 di 3
    • Remove the back battery cover.
    • Apply pressure on the cover while simultaneously sliding the cover downward.
  3. Nokia 6086 Keypad Replacement: passo 3, immagine 1 di 3 Nokia 6086 Keypad Replacement: passo 3, immagine 2 di 3 Nokia 6086 Keypad Replacement: passo 3, immagine 3 di 3
    • Insert the iPod opening tool between the base of the phone and the phone battery.
    • Position the phone so that the battery won't fall out of the phone.
    • The battery lifts out of the phone fast and easily.
    • Carefully lift the battery out of the phone.
  4. Nokia 6086 Keypad Replacement, Upper Back Cover: passo 4, immagine 1 di 1
    • Turn the phone so that the back of the phone is facing forward.
    • The picture to the left shows the location of the plastic tabs that attach to the upper cover of the phone.
    • In this picture, the upper cover has already been removed.
  5. Nokia 6086 Keypad Replacement: passo 5, immagine 1 di 2 Nokia 6086 Keypad Replacement: passo 5, immagine 2 di 2
    • Place the iPod opening tool under the tabs near the top of the phone.
    • Slide the iPod Opening Tool upwards.
    • This will pop the tabs and release the upper part of the phone.
    • Repeat for the left and the right sides.
  6. Nokia 6086 Keypad Replacement: passo 6, immagine 1 di 2 Nokia 6086 Keypad Replacement: passo 6, immagine 2 di 2
    • Place the iPod opening tool at the top area of the bottom section of the phone (indicated in picture).
    • Lift the iPod opening tool to pop open the clips.
    • This will release the upper back cover of the phone.
  7. Nokia 6086 Keypad Replacement: passo 7, immagine 1 di 3 Nokia 6086 Keypad Replacement: passo 7, immagine 2 di 3 Nokia 6086 Keypad Replacement: passo 7, immagine 3 di 3
    • Push upward on the top back cover using two thumbs.
    • This will remove the top back cover from the phone.
  8. Nokia 6086 Keypad Replacement, Base of The Phone: passo 8, immagine 1 di 2 Nokia 6086 Keypad Replacement, Base of The Phone: passo 8, immagine 2 di 2
    • Locate the four screws.
    • Remove the screws using a T6 Torx screwdriver.
  9. Nokia 6086 Keypad Replacement: passo 9, immagine 1 di 2 Nokia 6086 Keypad Replacement: passo 9, immagine 2 di 2
    • Turn the phone over.
    • Gently pull apart the phone.
    • Start at the bottom of the phone and pull outward.
    • There are plastic catches on the middle of each side. These should pop free as you pull.
    • Be careful, the phone will separate into two sections.
  10. Nokia 6086 Keypad Replacement: passo 10, immagine 1 di 2 Nokia 6086 Keypad Replacement: passo 10, immagine 2 di 2
    • The phone should now be in two different sections.
    • 1) The logic board and the back cover
    • 2) The keypad and the rest of the phone
  11. Nokia 6086 Keypad Replacement, Keypad: passo 11, immagine 1 di 1
    • Place the keypad in view.
  12. Nokia 6086 Keypad Replacement: passo 12, immagine 1 di 2 Nokia 6086 Keypad Replacement: passo 12, immagine 2 di 2
    • Remove the keypad from the phone by lifting the keypad off the phone.
  13. Nokia 6086 Keypad Replacement: passo 13, immagine 1 di 1
    • The keypad should be detached.
Conclusione
Caitlin Rahm
Membro da: 04/15/10
78 Reputazione
4 Guide realizzate
Cal Poly, Team 26-30, Regan Spring 2010 Membro di Cal Poly, Team 26-30, Regan Spring 2010
CPSU-REGAN-S10S26G30
4 Membri
17 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,160
