Introduzione
The microphone is an essential component of the Nokia 6085h as it is responsible for the transmission of the audio. Malfunction of the microphone may require replacement or repair, but first it needs to be located.
Follow this guide to help locate the microphone for removal or/and repair. Please be gentle with the tools as you remove each component of the Nokia 6085h.
Cosa ti serve
Flip over the phone so that the back is facing up.
Pressing your thumb against the back cover, slide the cover off of the phone.
Use the iFixit opening tool to pry out the two tabs at the top corners of the battery compartment.
Pry the keypad out with the plastic opening tool once the motherboard is moved out of the way.
Locate the small speaker module on the back of the separated battery compartment in the lower left hand corner.
