Introduzione
If your Nokia (model 6085h) phone happens to malfunction, you most likely have a worn-out battery, in which requires replacement.
A battery on a Nokia phone helps gain access to features, for example, making & receiving phone calls. Throughout the usage, the battery slowly drains when going through the charging process. If you notice that your phone is wasting more battery than usual, you should replace the battery.
In this guide, you will be able to find out where the battery is located, and how to remove the battery safely.
Before beginning, make sure your device is powered off and disconnected from any external power source(s). Have the new battery ready and set to the side.
Flip over the phone so that the back is facing up.
Pressing your thumb against the back cover, slide the cover off of the phone.
Altre 3 persone hanno completato questa guida.
