Salta al contenuto principale
Nokia 6030 Front Cover Replacement
  1. Nokia 6030 Front Cover Replacement, Battery: passo 1, immagine 1 di 3 Nokia 6030 Front Cover Replacement, Battery: passo 1, immagine 2 di 3 Nokia 6030 Front Cover Replacement, Battery: passo 1, immagine 3 di 3
    • Press down on the grip on the back of the phone and slide the rear housing down towards the bottom of the phone.
  2. Nokia 6030 Front Cover Replacement: passo 2, immagine 1 di 3 Nokia 6030 Front Cover Replacement: passo 2, immagine 2 di 3 Nokia 6030 Front Cover Replacement: passo 2, immagine 3 di 3
    • Use your finger to gently pull the bottom of the battery up by using the slip found at the bottom of the phone.
    • Lift out battery and remove.
  3. Nokia 6030 Front Cover Replacement, SIM Card: passo 3, immagine 1 di 3 Nokia 6030 Front Cover Replacement, SIM Card: passo 3, immagine 2 di 3 Nokia 6030 Front Cover Replacement, SIM Card: passo 3, immagine 3 di 3
    • Use your finger to lift the metal cage up.
    • Remove SIM card.
  4. Nokia 6030 Front Cover Replacement: passo 4, immagine 1 di 1
    • Use your finger to close the metal cage.
  5. Nokia 6030 Front Cover Replacement, Front Cover: passo 5, immagine 1 di 3 Nokia 6030 Front Cover Replacement, Front Cover: passo 5, immagine 2 di 3 Nokia 6030 Front Cover Replacement, Front Cover: passo 5, immagine 3 di 3
    • Insert your two fingers under the two tabs found at the top of the phone underneath the black casing, then pull the casing up and slide it out slowly.
  6. Nokia 6030 Front Cover Replacement: passo 6, immagine 1 di 2 Nokia 6030 Front Cover Replacement: passo 6, immagine 2 di 2
    • After removing the top cover, turn the phone over so the screen is facing upwards.
  7. Nokia 6030 Front Cover Replacement: passo 7, immagine 1 di 3 Nokia 6030 Front Cover Replacement: passo 7, immagine 2 di 3 Nokia 6030 Front Cover Replacement: passo 7, immagine 3 di 3
    • Use your fingers to slowly lift the screen back towards the bottom of the phone using the arrows found at the top of the phone.
Conclusione
Cal Poly, Team 23-63, Johann Spring 2010 Membro di Cal Poly, Team 23-63, Johann Spring 2010
CPSU-JOHANN-S10S23G63
3 Membri
17 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 3,088
