Introduzione
Use this guide to remove and replace the vibrator in the Nokia 6010.
Cosa ti serve
Press the small tab on the bottom of the back of the phone.
Push the back case upward towards the power button. The back case will then pop off.
With one hand, press the ridged tab near the visible side of the SIM card.
Slide the card out with your other hand.
Grip the phone on either the sides, the top, or the bottom.
Pull the front case away from the rest of the phone.
Remove the six screws around the front of the phone body with a T6 screwdriver.
Insert a spudger beneath the metallic shaft of the vibrator and pry it away from the phone.
