Salta al contenuto principale
Nokia 5310b XpressMusic Motherboard Replacement
Cosa ti serve
  1. Nokia 5310b XpressMusic Motherboard Replacement, Battery: passo 1, immagine 1 di 1
    • Slide the back cover down with your thumb.
    • *Note: the battery cover is not shown in this picture
  2. Nokia 5310b XpressMusic Motherboard Replacement: passo 2, immagine 1 di 2 Nokia 5310b XpressMusic Motherboard Replacement: passo 2, immagine 2 di 2
    • Gently lift the battery with a fingernail and remove it from its housing.
    • *Note: the battery may be replaced or repaired at this step
  3. Nokia 5310b XpressMusic Motherboard Replacement, Keypad: passo 3, immagine 1 di 3 Nokia 5310b XpressMusic Motherboard Replacement, Keypad: passo 3, immagine 2 di 3 Nokia 5310b XpressMusic Motherboard Replacement, Keypad: passo 3, immagine 3 di 3
    • On some models, the front case is screwed down from the back. Follow steps 5 and 6 FIRST to remove the camera cover and two T6 screws, before removing the faceplate.
    • Use the Spudger to gently pry up the edges of the front face plate
    • At the center of the faceplate edge below the music keys there is a small latch on each side.
    Before doing this step, first remove the camera cover and the two t6 screws from the back (steps 5 and 6). Otherwise you will break the cover. This may be a factor only for some revisions (RM-304)
    s c - Replica
  4. Nokia 5310b XpressMusic Motherboard Replacement: passo 4, immagine 1 di 2 Nokia 5310b XpressMusic Motherboard Replacement: passo 4, immagine 2 di 2
    • Lift up the keypad from the bottom with either the spudger or your finger.
    • Note: at this time the keypad can be removed and replaced
  5. Nokia 5310b XpressMusic Motherboard Replacement, Motherboard: passo 5, immagine 1 di 1
    • Gently unsnap the back camera cover from the phone.
    • Lift the cover from the phone after it is unsnapped.
  6. Nokia 5310b XpressMusic Motherboard Replacement: passo 6, immagine 1 di 2 Nokia 5310b XpressMusic Motherboard Replacement: passo 6, immagine 2 di 2
    • Use the T6 torx screwdriver head to remove the 2 screws on either side of the camera
    • Flip over the phone and again us the T6 torx head to remove the 4 screws located at each corner of the white keypad base
  7. Nokia 5310b XpressMusic Motherboard Replacement: passo 7, immagine 1 di 1
    • Unclip the faceplate plug (ribbon) located in the lower left corner of the motherboard
  8. Nokia 5310b XpressMusic Motherboard Replacement: passo 8, immagine 1 di 2 Nokia 5310b XpressMusic Motherboard Replacement: passo 8, immagine 2 di 2
    • Use the Spudger to pry up the 2 metal clips located near the center of the motherboard on both the left and right
    • At this point the phone should come apart into 2 pieces, the motherboard/LCD screen and the faceplate
Conclusione
Altre 4 persone hanno completato questa guida.
Max Kirby
Membro da: 05/01/11
518 Reputazione
4 Guide realizzate
Cal Poly, Team 15-14, Regan Spring 2011 Membro di Cal Poly, Team 15-14, Regan Spring 2011
CPSU-REGAN-S11S15G14
3 Membri
8 Guide realizzate
Un commento
Step 5 and 6 must be performed before step 3, otherwise, you will dislodge the thread from the front plate. so you have to remove the camera cover first, remove the 2 screws then you can remove the front plate without breaking anything.
Vincent Tschanz - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 6,841
