Salta al contenuto principale
Nokia 3360 Keypad Replacement
  1. Nokia 3360 Keypad Replacement, Battery: passo 1, immagine 1 di 1
    • Press down on the back of the phone with your thumb. Then slide the back plate upward toward the top of the phone.
    • Lift the back plate off the phone.
  2. Nokia 3360 Keypad Replacement: passo 2, immagine 1 di 2 Nokia 3360 Keypad Replacement: passo 2, immagine 2 di 2
    • To release the battery, press the two tabs that are located directly above the battery towards the top of the phone at the same time.
  3. Nokia 3360 Keypad Replacement: passo 3, immagine 1 di 2 Nokia 3360 Keypad Replacement: passo 3, immagine 2 di 2
    • Lift the battery out of the phone.
    • Note: Upon reassembly of the phone refer to second picture. The bottom of the battery with three square openings should line up with the prongs sticking out of the phone.
  4. Nokia 3360 Keypad Replacement, Cover Plate: passo 4, immagine 1 di 2 Nokia 3360 Keypad Replacement, Cover Plate: passo 4, immagine 2 di 2
    • Use finger nails of your thumbs to gently pull apart the face plate.
    • While the face plate is pulled apart, use index fingers to pull inner case towards you.
    • Separate faceplate and inner case.
  5. Nokia 3360 Keypad Replacement, Keypad: passo 5, immagine 1 di 1
    • Gently peel up the edge of plastic keypad from the inside of the faceplate to remove.
Conclusione
Altre 3 persone hanno completato questa guida.
Cal Poly, Team 8-39, Regan Winter 2010 Membro di Cal Poly, Team 8-39, Regan Winter 2010
CPSU-REGAN-W10S8G39
4 Membri
15 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 3,826
