Salta al contenuto principale
Nokia 3310 3G Screen Replacement
Cosa ti serve
  1. Nokia 3310 3G Screen Replacement, Battery: passo 1, immagine 1 di 2 Nokia 3310 3G Screen Replacement, Battery: passo 1, immagine 2 di 2
    • Using the thumbtab molded on the bottom of the phone, pry the back cover off using either a fingernail or a plastic opening tool.
  2. Nokia 3310 3G Screen Replacement: passo 2, immagine 1 di 2 Nokia 3310 3G Screen Replacement: passo 2, immagine 2 di 2
    • There is a molded notch in the white frame of the phone near the top right of the battery. Using either a finger or a plastic opening tool, utilize the notch to lift up on the battery, and remove it from the device.
    • This specific device did not come with a battery.
  3. Nokia 3310 3G Screen Replacement, Frame: passo 3, immagine 1 di 3 Nokia 3310 3G Screen Replacement, Frame: passo 3, immagine 2 di 3 Nokia 3310 3G Screen Replacement, Frame: passo 3, immagine 3 di 3
    • Using a T5 screwdriver bit, remove the (6) 5.0 mm screws along the outside edge of the frame.
    • Using a metal spudger, wedge the 6 plastic tabs molded into the outer shell away from the frame to lift up and remove it.
  4. Nokia 3310 3G Screen Replacement, Motherboard: passo 4, immagine 1 di 3 Nokia 3310 3G Screen Replacement, Motherboard: passo 4, immagine 2 di 3 Nokia 3310 3G Screen Replacement, Motherboard: passo 4, immagine 3 di 3
    • Use a spudger to simultaneously leverage the shell away and the motherboard up from the body of the shell.
  5. Nokia 3310 3G Screen Replacement, Screen: passo 5, immagine 1 di 3 Nokia 3310 3G Screen Replacement, Screen: passo 5, immagine 2 di 3 Nokia 3310 3G Screen Replacement, Screen: passo 5, immagine 3 di 3
    • With the motherboard removed, the only thing holding the screen into place is the snap plug on the back of the motherboard.
    • Using a spudger, leverage the top snap up to disconnect it (photo shows motherboard rotated 90 degrees counterclockwise).
Conclusione
Altre 6 persone hanno completato questa guida.
3Commenti sulla guida
If you can break the screen without taking it apart, then you must not be human
Feyrowan - Replica
The Cylons are greeting you.
M. H. -
Thank you!
I dont have cash for a new one,
but i could fix my old one.
There was soup on the display inside,
cleaned it, screen is clear now.
Yeay!
fred - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 47
Tutti i Tempi: 2,157
