Introduzione
In the event of a drop, the rear camera on the Nokia 3310 3G can be damaged. This guide will show the steps necessary to replace it.
Cosa ti serve
Using the thumbtab molded on the bottom of the phone, pry the back cover off using either a fingernail or a plastic opening tool.
Using a T5 screwdriver bit, remove the (6) 5.0 mm screws along the outside edge of the frame.
Using a metal spudger, wedge the 6 plastic tabs molded into the outer shell away from the frame to lift up and remove it.
Using the pointed metal spudger from the metal spudger set, insert the tool underneath the small snap clip, and disconnect it by lifting it up.
Altre 3 persone hanno completato questa guida.
