Salta al contenuto principale
Nokia 3120 SIM Card Replacement
Cosa ti serve
  1. Nokia 3120 SIM Card Replacement, Battery Installation: passo 1, immagine 1 di 3 Nokia 3120 SIM Card Replacement, Battery Installation: passo 1, immagine 2 di 3 Nokia 3120 SIM Card Replacement, Battery Installation: passo 1, immagine 3 di 3
    • Remove the back cover plate of the phone. To do this press down the lock as you slide the cover toward the bottom of the phone.
  2. Nokia 3120 SIM Card Replacement: passo 2, immagine 1 di 1
    • Once the back cover plate is removed, the battery should be exposed. Remove the battery by prying it out. This can be done with your finger-nail or a prying tool.
  3. Nokia 3120 SIM Card Replacement, SIM Card: passo 3, immagine 1 di 1
    • Once the battery is removed, the SIM card compartment will be exposed. Pry the compartment open as seen in the figure. This can be done using your fingernail or a prying mechanism.
  4. Nokia 3120 SIM Card Replacement: passo 4, immagine 1 di 1
    • Once the SIM card compartment has been opened, insert the SIM card into the slot provided on the left side.
Conclusione
Altre 3 persone hanno completato questa guida.
Clemson, Team 13-2, Benson Spring 2013 Membro di Clemson, Team 13-2, Benson Spring 2013
CLEM-BENSON-S13S13G2
3 Membri
14 Guide realizzate
1Commento della guida
Thanks , appreciated.
Ian McCully - Replica Condividi
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 58
Tutti i Tempi: 6,041
