Introduzione
The LCD is difficult to get to and the guide requires a moderate amount of work. Tiny parts require patience during disassembly.
Parti
Nessuna parte richiesta.
  1. Remove the back cover plate of the phone.  To do this press down the lock as you slide the cover toward the bottom of the phone. Remove the back cover plate of the phone.  To do this press down the lock as you slide the cover toward the bottom of the phone. Remove the back cover plate of the phone.  To do this press down the lock as you slide the cover toward the bottom of the phone.
    • Remove the back cover plate of the phone. To do this press down the lock as you slide the cover toward the bottom of the phone.
  2. Once the back cover plate is removed, the battery should be exposed. Remove the battery by prying it out.  This can be done with your finger-nail or a prying tool.
    • Once the back cover plate is removed, the battery should be exposed. Remove the battery by prying it out. This can be done with your finger-nail or a prying tool.
  3. Using your fingernails or another tool, pry the front face plate out along its edges and corners. Using your fingernails or another tool, pry the front face plate out along its edges and corners. Using your fingernails or another tool, pry the front face plate out along its edges and corners.
    • Using your fingernails or another tool, pry the front face plate out along its edges and corners.
  4. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  5. Once the cover plate has been removed, the keypad should easily pop out.
    • Once the cover plate has been removed, the keypad should easily pop out.
  6. Using a screwdriver, remove the 6, 7 mm Torx-head screws on the front of the phone. Using a screwdriver, remove the 6, 7 mm Torx-head screws on the front of the phone.
    • Using a screwdriver, remove the 6, 7 mm Torx-head screws on the front of the phone.
  7. Once the screws have been removed, the front plate of the phone should be removed, exposing the inside electronic components of the phone.
    • Once the screws have been removed, the front plate of the phone should be removed, exposing the inside electronic components of the phone.
  8. Take out the cell phone electronic board
    • Take out the cell phone electronic board
  9. The LCD screen can now be removed from the body of the phone.
    • The LCD screen can now be removed from the body of the phone.
Conclusione
Pierre Tong
Membro da: 11/03/2013
53 Reputazione
4 Guide realizzate
Clemson, Team 13-2, Benson Spring 2013 Membro di Clemson, Team 13-2, Benson Spring 2013
CLEM-BENSON-S13S13G2
3 Membri
14 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 12
Tutti i Tempi: 986
