Salta al contenuto principale
Nokia 3120 Keypad Replacement
  1. Nokia 3120 Keypad Replacement, Battery Installation: passo 1, immagine 1 di 3 Nokia 3120 Keypad Replacement, Battery Installation: passo 1, immagine 2 di 3 Nokia 3120 Keypad Replacement, Battery Installation: passo 1, immagine 3 di 3
    • Remove the back cover plate of the phone. To do this press down the lock as you slide the cover toward the bottom of the phone.
  2. Nokia 3120 Keypad Replacement: passo 2, immagine 1 di 1
    • Once the back cover plate is removed, the battery should be exposed. Remove the battery by prying it out. This can be done with your finger-nail or a prying tool.
  3. Nokia 3120 Keypad Replacement, Face Plate: passo 3, immagine 1 di 3 Nokia 3120 Keypad Replacement, Face Plate: passo 3, immagine 2 di 3 Nokia 3120 Keypad Replacement, Face Plate: passo 3, immagine 3 di 3
    • Using your fingernails or another tool, pry the front face plate out along its edges and corners.
  4. Nokia 3120 Keypad Replacement, Keypad: passo 4, immagine 1 di 1
    • Once the cover plate has been removed, the existing keypad should be easily removed.
    • To install a new keypad, simply place the new keypad in the same place where the old keypad was.
Conclusione
Pierre Tong
Membro da: 03/11/13
77 Reputazione
4 Guide realizzate
Clemson, Team 13-2, Benson Spring 2013 Membro di Clemson, Team 13-2, Benson Spring 2013
CLEM-BENSON-S13S13G2
3 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 757
