Salta al contenuto principale
Nokia 2630b Antenna Replacement
Cosa ti serve
  1. Nokia 2630b Antenna Replacement, Battery Case: passo 1, immagine 1 di 2 Nokia 2630b Antenna Replacement, Battery Case: passo 1, immagine 2 di 2
    • Press each release button on either side of the battery cover and simultaneously remove the battery cover from the phone.
  2. Nokia 2630b Antenna Replacement: passo 2, immagine 1 di 1
    • Pull the battery out of the phone with your fingers.
  3. Nokia 2630b Antenna Replacement, Screen / Front Case: passo 3, immagine 1 di 1
    • Remove the two screws on either side of the battery case using the microscrewdriver using the T5 bit
    • The T5 bit has a star shaped end and has "T5" engraved on the side of the bit for easy identification
    • NOTE: Keep the screws in a safe place while you continue working.
  4. Nokia 2630b Antenna Replacement: passo 4, immagine 1 di 3 Nokia 2630b Antenna Replacement: passo 4, immagine 2 di 3 Nokia 2630b Antenna Replacement: passo 4, immagine 3 di 3
    • Separate the front case from the back case using the iPod opener
    • NOTE: The keypad is a loose piece and may fall out
  5. Nokia 2630b Antenna Replacement: passo 5, immagine 1 di 1
    • Remove screws using the same T5 screw bit to release the computer chip from the case
  6. Nokia 2630b Antenna Replacement: passo 6, immagine 1 di 1
    • Carefully lift the black frame off the screen with your fingers
  7. Nokia 2630b Antenna Replacement: passo 7, immagine 1 di 1
    • Carefully remove the computer chip and screen out of the black case with your fingers
  8. Nokia 2630b Antenna Replacement: passo 8, immagine 1 di 2 Nokia 2630b Antenna Replacement: passo 8, immagine 2 di 2
    • The screen is attached to the motherboard by an orange ribbon
    • Carefully detach the ribbon from the motherboard using your fingers
  9. Nokia 2630b Antenna Replacement: passo 9, immagine 1 di 1
    • Reattach new screen by connecting the orange ribbon to the computer chip
  10. Nokia 2630b Antenna Replacement: passo 10, immagine 1 di 2 Nokia 2630b Antenna Replacement: passo 10, immagine 2 di 2
    • Place computer chip and screen back into black case
  11. Nokia 2630b Antenna Replacement: passo 11, immagine 1 di 1
    • Place black frame back over screen
  12. Nokia 2630b Antenna Replacement: passo 12, immagine 1 di 2 Nokia 2630b Antenna Replacement: passo 12, immagine 2 di 2
    • Carefully place keypad back in place
  13. Nokia 2630b Antenna Replacement: passo 13, immagine 1 di 2 Nokia 2630b Antenna Replacement: passo 13, immagine 2 di 2
    • Snap the front case back in place with the bottom case with your fingers
  14. Nokia 2630b Antenna Replacement: passo 14, immagine 1 di 1
    • Reassemble screws with microscrewdriver
  15. Nokia 2630b Antenna Replacement: passo 15, immagine 1 di 1
    • Slide battery back into place
  16. Nokia 2630b Antenna Replacement: passo 16, immagine 1 di 1
    • Snap battery cover back into place
  17. Nokia 2630b Antenna Replacement, Back Case: passo 17, immagine 1 di 2 Nokia 2630b Antenna Replacement, Back Case: passo 17, immagine 2 di 2
    • Locate the four screws that secure the back case to the rest of the phone.
    • Unscrew all four screws using a "T-5" star shaped screw driver, turning counter-clockwise.
  18. Nokia 2630b Antenna Replacement: passo 18, immagine 1 di 3 Nokia 2630b Antenna Replacement: passo 18, immagine 2 di 3 Nokia 2630b Antenna Replacement: passo 18, immagine 3 di 3
    • DO NOT PULL APART! There is a wire attaching the speaker to the rear case. It is very important to NOT sever this connection. Because of this, the rear case does not completely detach from the rest of the phone.
    • Holding the rear case, applying pressure to the back of the phone near the location of the battery in order to separate the two components.
  19. Nokia 2630b Antenna Replacement, Antenna: passo 19, immagine 1 di 1
    • The antenna is the "L" shaped device located on the top of the phone in between the back case and the board.
    • You should be able to remove the antenna with minimal effort.
    • To put in a new antenna, place it in the same location as the old one. There is no need to connect to any hardware on the phone.
  20. Nokia 2630b Antenna Replacement: passo 20, immagine 1 di 1
    • To reassemble the device, follow the instructions in reverse order.
    • When reinstalling the keyboard, make sure it is in the correct position before screwing the case back together.
    • When reinstalling the battery, make sure the contacts of the battery connect to the contacts on the phone.
    • The red square in the photo indicates the position of the brass contacts of the battery.
    • The photo displays the correct orientation of the battery.
Linea Traguardo
Eric
Membro da: 04/07/11
51 Reputazione
4 Guide realizzate
Cal Poly, Team 9-61, Walters Spring 2011 Membro di Cal Poly, Team 9-61, Walters Spring 2011
CPSU-WALTERS-S11S9G61
5 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 8
Tutti i Tempi: 3,443
