Introduzione
After you have successfully completed the faceplate and circuit board removal guide this guide will show you how to replace the speaker
Cosa ti serve
Place your thumb on the middle of the back cover and push it toward the bottom of the phone to slide the cover off.
Insert the plastic opening tool into the crack between the front and back panels.
Gently pry the front cover away from the back cover while sliding the plastic opening tool towards the top of the phone.
Use the Torx screwdriver with the T6 attachmet to remove the 6 .4 mm screws around the outside of the circuit board.
Using the plastic opening tool, gently pry the speaker out of its slot in the back cover of the phone.
Altre 2 persone hanno completato questa guida.
