Parti
Nessuna parte richiesta.
  1. Place your thumb on the middle of the back cover and push it toward the bottom of the phone to slide the cover off. Place your thumb on the middle of the back cover and push it toward the bottom of the phone to slide the cover off. Place your thumb on the middle of the back cover and push it toward the bottom of the phone to slide the cover off.
    • Place your thumb on the middle of the back cover and push it toward the bottom of the phone to slide the cover off.
  2. Use a plastic opening tool (or your finger) to gently pry the battery out of the battery slot on the back of the phone. Use a plastic opening tool (or your finger) to gently pry the battery out of the battery slot on the back of the phone. Use a plastic opening tool (or your finger) to gently pry the battery out of the battery slot on the back of the phone.
    • Use a plastic opening tool (or your finger) to gently pry the battery out of the battery slot on the back of the phone.
  3. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  4. Lift the metal sim card holder (at the bottom of the battery slot) up and carefully pry the sim card out of its slot with a plastic opening tool or your finger. After removal, lower the metal sim card holder into its original position. After removal, lower the metal sim card holder into its original position.
    • Lift the metal sim card holder (at the bottom of the battery slot) up and carefully pry the sim card out of its slot with a plastic opening tool or your finger.
    • After removal, lower the metal sim card holder into its original position.
  5. Insert the plastic opening tool into the crack between the front and back panels. Gently pry the front cover away from the back cover while sliding the plastic opening tool towards the top of the phone.
    • Insert the plastic opening tool into the crack between the front and back panels.
    • Gently pry the front cover away from the back cover while sliding the plastic opening tool towards the top of the phone.
  6. Lift the bottom of the front cover away from the phone. Continue lifting until the top of the front cover is fully removed from the phone.
    • Lift the bottom of the front cover away from the phone.
    • Continue lifting until the top of the front cover is fully removed from the phone.
    • Note: To replace the Keypad, gently lift it out of the front cover. It is located below the clear viewing window.
  7. Push on the keypad from the exterior of the phone's front cover to separate the keypad from the phone. Push on the keypad from the exterior of the phone's front cover to separate the keypad from the phone.
    • Push on the keypad from the exterior of the phone's front cover to separate the keypad from the phone.
Conclusione
Jeff Carter
Membro da: 05/10/2010
91 Reputazione
1 Guida realizzata
Cal Poly, Team 7-52, Amido Fall 2010 Membro di Cal Poly, Team 7-52, Amido Fall 2010
CPSU-AMIDO-F10S7G52
4 Membri
12 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,899
