Salta al contenuto principale
Nokia 2610 Front Pannel Replacement
Cosa ti serve
  1. Nokia 2610 Front Pannel Replacement, Battery and Sim Card: passo 1, immagine 1 di 3 Nokia 2610 Front Pannel Replacement, Battery and Sim Card: passo 1, immagine 2 di 3 Nokia 2610 Front Pannel Replacement, Battery and Sim Card: passo 1, immagine 3 di 3
    • Place your thumb on the middle of the back cover and push it toward the bottom of the phone to slide the cover off.
  2. Nokia 2610 Front Pannel Replacement: passo 2, immagine 1 di 3 Nokia 2610 Front Pannel Replacement: passo 2, immagine 2 di 3 Nokia 2610 Front Pannel Replacement: passo 2, immagine 3 di 3
    • Use a plastic opening tool (or your finger) to gently pry the battery out of the battery slot on the back of the phone.
  3. Nokia 2610 Front Pannel Replacement: passo 3, immagine 1 di 3 Nokia 2610 Front Pannel Replacement: passo 3, immagine 2 di 3 Nokia 2610 Front Pannel Replacement: passo 3, immagine 3 di 3
    • Lift the metal sim card holder (at the bottom of the battery slot) up and carefully pry the sim card out of its slot with a plastic opening tool or your finger.
    • After removal, lower the metal sim card holder into its original position.
  4. Nokia 2610 Front Pannel Replacement, Front Pannel: passo 4, immagine 1 di 2 Nokia 2610 Front Pannel Replacement, Front Pannel: passo 4, immagine 2 di 2
    • Insert the plastic opening tool into the crack between the front and back panels.
    • Gently pry the front cover away from the back cover while sliding the plastic opening tool towards the top of the phone.
  5. Nokia 2610 Front Pannel Replacement: passo 5, immagine 1 di 2 Nokia 2610 Front Pannel Replacement: passo 5, immagine 2 di 2
    • Lift the bottom of the front cover away from the phone.
    • Continue lifting until the top of the front cover is fully removed from the phone.
    • Note: To replace the Keypad, gently lift it out of the front cover. It is located below the clear viewing window.
Conclusione
Altre 3 persone hanno completato questa guida.
Andrew Wood
Membro da: 10/05/10
336 Reputazione
3 Guide realizzate
Cal Poly, Team 7-52, Amido Fall 2010 Membro di Cal Poly, Team 7-52, Amido Fall 2010
CPSU-AMIDO-F10S7G52
4 Membri
12 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 59
Tutti i Tempi: 2,420
