Salta al contenuto principale
Nokia 2366i Battery Replacement
Cosa ti serve
  1. Nokia 2366i Battery Replacement, Battery: passo 1, immagine 1 di 2 Nokia 2366i Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Turn off the phone.
    • Position the phone so that the back side is in view.
  2. Nokia 2366i Battery Replacement: passo 2, immagine 1 di 1
    • Apply pressure on the cover while simultaneously sliding the cover downward.
    • Remove the back battery cover.
  3. Nokia 2366i Battery Replacement: passo 3, immagine 1 di 3 Nokia 2366i Battery Replacement: passo 3, immagine 2 di 3 Nokia 2366i Battery Replacement: passo 3, immagine 3 di 3
    • Insert the spudger between the base of the phone and the phone battery.
    • Position the phone so that the battery won't fall out of the phone.
    • Carefully lift the battery out of the phone.
    • The battery lifts out of the phone easily.
Conclusione
Cal Poly, Team 1-14, Amido Winter 2011 Membro di Cal Poly, Team 1-14, Amido Winter 2011
CPSU-AMIDO-W11S1G14
5 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 18
Tutti i Tempi: 1,439
