Parti
Nessuna parte richiesta.
  1. Be sure cell phone is off before you begin to disassemble the phone.
    • Be sure cell phone is off before you begin to disassemble the phone.
    • Press the button on the bottom of the back of the cell phone.
    • Slide rear panel down and remove it.
    Aggiungi Commento
  2. Using your fingernail, pry the back of the battery upwards and pull out.
    • Using your fingernail, pry the back of the battery upwards and pull out.
    Aggiungi Commento
    • Insert the plastic opening tool under the faceplate.
    • Separate the faceplate from main body by twisting the prying tool with some force.
    • The faceplate is held by three plastic fasteners, so pry evenly on both sides of phone.
    Aggiungi Commento
    • With the faceplate removed, simply peel off rubber key pad and remove.
    Aggiungi Commento
    • Locate and remove the six screws on the front of the phone using a T6 Torx.
      • All 6 screws are 6.9mm long.
    Aggiungi Commento
    • After removing screws, lift the motherboard assembly straight off the cell phone body.
    Aggiungi Commento
    • Locate the two plastic LCD unit hooks.
    • Pry hooks outward.
    Aggiungi Commento
    • Gently pull LCD unit away from the logic board.
      • Be careful not to damage the connection on the top, right hand side of the logic board.
    Aggiungi Commento
    • With the LCD unit removed, gently press out the speaker with a non-metallic pointed object.
    Aggiungi Commento
Conclusione
Cal Poly, Team 20-8, Maness Fall 2010 Membro di Cal Poly, Team 20-8, Maness Fall 2010
CPSU-MANESS-F10S20G8
4 Membri
28 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 189
