Parti
Nessuna parte richiesta.
Insert the plastic opening tool under the faceplate.
  • Insert the plastic opening tool under the faceplate.
  • Separate the faceplate from main body by twisting the prying tool with some force.
  • The faceplate is held by three plastic fasteners, so pry evenly on both sides of phone.
Aggiungi Commento
With the faceplate removed, simply peel off rubber key pad and remove.
  • With the faceplate removed, simply peel off rubber key pad and remove.
Aggiungi Commento
  • Locate and remove the six screws on the front of the phone using a T6 Torx.
    • All 6 screws are 6.9mm long.
Aggiungi Commento
  • After removing screws, lift the motherboard assembly straight off the cell phone body.
Aggiungi Commento
  • Be sure cell phone is off before you begin to disassemble the phone.
  • Press the button on the bottom of the back of the cell phone.
  • Slide rear panel down and remove it.
Aggiungi Commento
  • Using your fingernail, pry the back of the battery upwards and pull out.
Aggiungi Commento
  • With the LCD unit removed, gently press out the speaker with a non-metallic pointed object.
Aggiungi Commento
Conclusione
Cal Poly, Team 20-8, Maness Fall 2010 Membro di Cal Poly, Team 20-8, Maness Fall 2010
CPSU-MANESS-F10S20G8
4 Membri
28 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 217
