Salta al contenuto principale
Nokia 2128i Internal Clock Battery Replacement
Cosa ti serve
  1. Nokia 2128i Internal Clock Battery Replacement, Battery: passo 1, immagine 1 di 3 Nokia 2128i Internal Clock Battery Replacement, Battery: passo 1, immagine 2 di 3 Nokia 2128i Internal Clock Battery Replacement, Battery: passo 1, immagine 3 di 3
    • Be sure cell phone is off before you begin to disassemble the phone.
    • Press the button on the bottom of the back of the cell phone.
    • Slide rear panel down and remove it.
  2. Nokia 2128i Internal Clock Battery Replacement: passo 2, immagine 1 di 3 Nokia 2128i Internal Clock Battery Replacement: passo 2, immagine 2 di 3 Nokia 2128i Internal Clock Battery Replacement: passo 2, immagine 3 di 3
    • Using your fingernail, pry the back of the battery upwards and pull out.
  3. Nokia 2128i Internal Clock Battery Replacement, Faceplate: passo 3, immagine 1 di 3 Nokia 2128i Internal Clock Battery Replacement, Faceplate: passo 3, immagine 2 di 3 Nokia 2128i Internal Clock Battery Replacement, Faceplate: passo 3, immagine 3 di 3
    • Insert the plastic opening tool under the faceplate.
    • Separate the faceplate from main body by twisting the prying tool with some force.
    • The faceplate is held by three plastic fasteners, so pry evenly on both sides of phone.
  4. Nokia 2128i Internal Clock Battery Replacement, Keypad: passo 4, immagine 1 di 3 Nokia 2128i Internal Clock Battery Replacement, Keypad: passo 4, immagine 2 di 3 Nokia 2128i Internal Clock Battery Replacement, Keypad: passo 4, immagine 3 di 3
    • With the faceplate removed, simply peel off rubber key pad and remove.
  5. Nokia 2128i Internal Clock Battery Replacement, Motherboard Assembly: passo 5, immagine 1 di 3 Nokia 2128i Internal Clock Battery Replacement, Motherboard Assembly: passo 5, immagine 2 di 3 Nokia 2128i Internal Clock Battery Replacement, Motherboard Assembly: passo 5, immagine 3 di 3
    • Locate and remove the six screws on the front of the phone using a T6 Torx.
    • All 6 screws are 6.9mm long.
  6. Nokia 2128i Internal Clock Battery Replacement: passo 6, immagine 1 di 3 Nokia 2128i Internal Clock Battery Replacement: passo 6, immagine 2 di 3 Nokia 2128i Internal Clock Battery Replacement: passo 6, immagine 3 di 3
    • After removing screws, lift the motherboard assembly straight off the cell phone body.
  7. Nokia 2128i Internal Clock Battery Replacement, Internal Clock Battery: passo 7, immagine 1 di 2 Nokia 2128i Internal Clock Battery Replacement, Internal Clock Battery: passo 7, immagine 2 di 2
    • With the logic board completely removed, gently pry out the internal clock battery from its housing.
    Why do you call the built-in microphone "Internal clock battery"?
    Алексей Пурис - Replica
Conclusione
Cal Poly, Team 20-8, Maness Fall 2010 Membro di Cal Poly, Team 20-8, Maness Fall 2010
CPSU-MANESS-F10S20G8
4 Membri
24 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 3,363
