Salta al contenuto principale
Nokia 1100b RH-36 Motherboard and Keyboard Replacement
Cosa ti serve
  1. Nokia 1100b RH-36 Motherboard and Keyboard Replacement, Battery Cover: passo 1, immagine 1 di 2 Nokia 1100b RH-36 Motherboard and Keyboard Replacement, Battery Cover: passo 1, immagine 2 di 2
    • Flip the phone over so that the screen faces down.
    • Press the gray button on the battery cover and slide it down off the back of the phone.
  2. Nokia 1100b RH-36 Motherboard and Keyboard Replacement, Battery: passo 2, immagine 1 di 1
    • Wedge the flat end of the spudger into the small indent next to the Nokia logo on the battery.
    • Gently pry the battery out of the phone.
  3. Nokia 1100b RH-36 Motherboard and Keyboard Replacement, Inner Casing: passo 3, immagine 1 di 2 Nokia 1100b RH-36 Motherboard and Keyboard Replacement, Inner Casing: passo 3, immagine 2 di 2
    • Remove the six 6mm T6 Torx screws around the edge of the front of the phone.
    • Remove the metal frame holding the screen and speaker.
  4. Nokia 1100b RH-36 Motherboard and Keyboard Replacement, Motherboard and Keyboard: passo 4, immagine 1 di 2 Nokia 1100b RH-36 Motherboard and Keyboard Replacement, Motherboard and Keyboard: passo 4, immagine 2 di 2
    • Gently lift motherboard unit out of the case.
    • The motherboard and keyboard are one unit and are replaced together.
Conclusione
Altre 13 persone hanno completato questa guida.
Cal Poly, Team 10-43, Amido Spring 2013 Membro di Cal Poly, Team 10-43, Amido Spring 2013
CPSU-AMIDO-S13S10G43
4 Membri
14 Guide realizzate
1Commento della guida
you nokia 1100 mother board please soon date…?
ajay gupta - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 24
Tutti i Tempi: 4,919
