Salta al contenuto principale
Nokero SunRay Pro Power Panel Capacitor Replacement
Cosa ti serve
  1. Nokero SunRay Pro Power Panel Capacitor Replacement, Front and Back Case: passo 1, immagine 1 di 1
    • Turn over the device so that the back of the device is facing up.
  2. Nokero SunRay Pro Power Panel Capacitor Replacement: passo 2, immagine 1 di 3 Nokero SunRay Pro Power Panel Capacitor Replacement: passo 2, immagine 2 di 3 Nokero SunRay Pro Power Panel Capacitor Replacement: passo 2, immagine 3 di 3
    • Insert the first plastic opening tool along the side to pry open the case.
    • Sliding the plastic opening tool, while inserted, along the seam may help the removal process.
    • Use a second plastic opening tool to help separate the remaining seams.
  3. Nokero SunRay Pro Power Panel Capacitor Replacement: passo 3, immagine 1 di 2 Nokero SunRay Pro Power Panel Capacitor Replacement: passo 3, immagine 2 di 2
    • There is a long strip of double sided adhesive foam tape that prevents the back case from easily being removed.
    • Pull the back case off by applying steady pressure to remove it from the adhesive foam tape.
  4. Nokero SunRay Pro Power Panel Capacitor Replacement: passo 4, immagine 1 di 2 Nokero SunRay Pro Power Panel Capacitor Replacement: passo 4, immagine 2 di 2
    • Use the Phillips precision screwdriver to unscrew the two 5.0 mm Phillips screws from the circuit board.
    • Remove the solar panel and circuit board from the front case.
  5. Nokero SunRay Pro Power Panel Capacitor Replacement, Capacitor: passo 5, immagine 1 di 1
    • Use the soldering station to desolder the two contact points around the connections of the capacitor to loosen the metal.
  6. Nokero SunRay Pro Power Panel Capacitor Replacement: passo 6, immagine 1 di 1
    • Pull the capacitor through the circuit board to remove it.
Conclusione
Nicholas Orr
Membro da: 01/20/15
229 Reputazione
2 Guide realizzate
USF Tampa, Team 9-3, Blackwell Winter 2015 Membro di USF Tampa, Team 9-3, Blackwell Winter 2015
USFT-BLACKWELL-W15S9G3
3 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 17
Tutti i Tempi: 171
