Salta al contenuto principale
Nokero N400 Switch Replacement
Cosa ti serve
  1. Nokero N400 Switch Replacement, Remove Battery Cover: passo 1, immagine 1 di 3 Nokero N400 Switch Replacement, Remove Battery Cover: passo 1, immagine 2 di 3 Nokero N400 Switch Replacement, Remove Battery Cover: passo 1, immagine 3 di 3
    • Press down firmly to remove the battery cover and display battery.
    • Then remove the battery.
  2. Nokero N400 Switch Replacement, Unscrew Back Cover: passo 2, immagine 1 di 2 Nokero N400 Switch Replacement, Unscrew Back Cover: passo 2, immagine 2 di 2
    • Remove the 7mm Phillips #1 screw.
  3. Nokero N400 Switch Replacement, Pry Open Back Cover: passo 3, immagine 1 di 2 Nokero N400 Switch Replacement, Pry Open Back Cover: passo 3, immagine 2 di 2
    • Place the plastic opening tool in between the two plastic panels and slowly work your way around the device.
    • Unlatch the clips on the inside and pull device apart.
    • Some clips will break when forced open.
  4. Nokero N400 Switch Replacement, Remove Switch From Housing: passo 4, immagine 1 di 1
    • Using a spudger carefully pry switch from housing.
  5. Nokero N400 Switch Replacement, Cut Old Switch Free: passo 5, immagine 1 di 1
    • Use wire cutters to cut the two black wires attached to the old switch.
    • You must use a splicer or a soldering gun to reattach the wires of the new switch.
    • If you splice the new switch wires together in the opposite order of the old switch wires, the new switch will still work.
Conclusione
Benjamin franklin
Membro da: 01/20/15
101 Reputazione
1 Guida realizzata
USF Tampa, Team 19-2, Blackwell Winter 2015 Membro di USF Tampa, Team 19-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S19G2
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 158
