Salta al contenuto principale
Nokero N400 Suction Cup Replacement
Cosa ti serve
  1. Nokero N400 Suction Cup Replacement, Remove Battery Cover: passo 1, immagine 1 di 3 Nokero N400 Suction Cup Replacement, Remove Battery Cover: passo 1, immagine 2 di 3 Nokero N400 Suction Cup Replacement, Remove Battery Cover: passo 1, immagine 3 di 3
    • Press down firmly to remove the battery cover and display battery.
    • Then remove the battery.
  2. Nokero N400 Suction Cup Replacement, Unscrew Back Cover: passo 2, immagine 1 di 2 Nokero N400 Suction Cup Replacement, Unscrew Back Cover: passo 2, immagine 2 di 2
    • Remove the 7mm Phillips #1 screw.
  3. Nokero N400 Suction Cup Replacement, Pry Open Back Cover: passo 3, immagine 1 di 2 Nokero N400 Suction Cup Replacement, Pry Open Back Cover: passo 3, immagine 2 di 2
    • Place the plastic opening tool in between the two plastic panels and slowly work your way around the device.
    • Unlatch the clips on the inside and pull device apart.
    • Some clips will break when forced open.
  4. Nokero N400 Suction Cup Replacement, Begin Removal: passo 4, immagine 1 di 2 Nokero N400 Suction Cup Replacement, Begin Removal: passo 4, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using tweezers, push the edges of the back end of the suction cup inward.
  5. Nokero N400 Suction Cup Replacement, Remove Suction Cup: passo 5, immagine 1 di 2 Nokero N400 Suction Cup Replacement, Remove Suction Cup: passo 5, immagine 2 di 2
    • Flip the cover over and remove the suction cup by pulling at an angle.
    • Be careful not to tear the plastic housing.
    • During reassembly, make sure to press down uniformly on the suction cup for an even fit.
Conclusione
Daniel Bumiller
Membro da: 01/20/15
201 Reputazione
2 Guide realizzate
USF Tampa, Team 19-2, Blackwell Winter 2015 Membro di USF Tampa, Team 19-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S19G2
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 10
Tutti i Tempi: 143
