Introduzione
If the suction cup no longer sticks to surfaces or if the plastic has split, you will need to replace the suction cup with a new one.
Cosa ti serve
Press down firmly to remove the battery cover and display battery.
Then remove the battery.
Place the plastic opening tool in between the two plastic panels and slowly work your way around the device.
Unlatch the clips on the inside and pull device apart.
Using tweezers, push the edges of the back end of the suction cup inward.
Flip the cover over and remove the suction cup by pulling at an angle.
