Salta al contenuto principale
Nokero N222-Huron O-Ring Replacement
Cosa ti serve
  1. Nokero N222-Huron O-Ring Replacement, Clear Cover: passo 1, immagine 1 di 1
    • Grasp the clear cover and the white housing and twist the cover counter-clockwise.
    • The lid may hold fast, but it will come off with some firm twisting.
  2. Nokero N222-Huron O-Ring Replacement: passo 2, immagine 1 di 1
    • Lift the lid from the device
    • It may be helpful to use a spudger to pry under the lid if there is difficulty in getting a good grip on the smooth plastic.
  3. Nokero N222-Huron O-Ring Replacement, O-Ring: passo 3, immagine 1 di 3 Nokero N222-Huron O-Ring Replacement, O-Ring: passo 3, immagine 2 di 3 Nokero N222-Huron O-Ring Replacement, O-Ring: passo 3, immagine 3 di 3
    • Using a plastic spudger, lift the o-ring from the lid
  4. Nokero N222-Huron O-Ring Replacement: passo 4, immagine 1 di 1
    • Gently stretch the new O-ring and place it in position on the clear cover. Make sure it is flush with the flange and not interfering with the locking threads
Conclusione
Vinny Capone
Membro da: 10/18/13
549 Reputazione
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 9
Tutti i Tempi: 204
