Introduzione
Keeping your device water-proof is paramount in using it to its full potential. Follow this guide to replace the water-proofing O-ring.
Parti
Nessuna parte richiesta.
Grasp the clear cover and the white housing and twist the cover counter-clockwise.
  • Grasp the clear cover and the white housing and twist the cover counter-clockwise.
  • The lid may hold fast, but it will come off with some firm twisting.
Aggiungi Commento
Lift the lid from the device
  • Lift the lid from the device
  • It may be helpful to use a spudger to pry under the lid if there is difficulty in getting a good grip on the smooth plastic.
Aggiungi Commento
  • Using a plastic spudger, lift the o-ring from the lid
Aggiungi Commento
  • Gently stretch the new O-ring and place it in position on the clear cover. Make sure it is flush with the flange and not interfering with the locking threads
Aggiungi Commento
Conclusione
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 97
