Salta al contenuto principale
Nobis NB09 Battery Replacement
Cosa ti serve
  1. Nobis NB09 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Before beginning this process, make sure the device is powered off.
    • Remove the screws holding the case together.
  2. Nobis NB09 Battery Replacement: passo 2, immagine 1 di 3 Nobis NB09 Battery Replacement: passo 2, immagine 2 di 3 Nobis NB09 Battery Replacement: passo 2, immagine 3 di 3
    • Use an opening tool to loosen and pry off the pink back plate.
  3. Nobis NB09 Battery Replacement: passo 3, immagine 1 di 2 Nobis NB09 Battery Replacement: passo 3, immagine 2 di 2
    • Remove the black electronic tape covering the circuit board.
  4. Nobis NB09 Battery Replacement: passo 4, immagine 1 di 1
    • Use the soldering iron to remove the black and red wires from the circuit board.
    • The black wire is the ground and the red wire is the battery positive terminal.
    • To reassemble, use the soldering iron to solder the leads at the end of the black (-) and red (+) wires from the new battery onto the proper terminals on the circuit board.
  5. Nobis NB09 Battery Replacement: passo 5, immagine 1 di 2 Nobis NB09 Battery Replacement: passo 5, immagine 2 di 2
    • Gently loosen the adhesive under the battery to avoid damaging it.
    • Use caution; the battery is soft and will bend very easily.
    • Dispose of the old battery properly at an electronic waste center or verified battery recycling store.
    • When reassembling, apply adhesive to the back of the new battery.
Conclusione
Altre 3 persone hanno completato questa guida.
Un commento
where can i buy a battery from
Frederick Shipman - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 15
Tutti i Tempi: 2,958
