Salta al contenuto principale
Nixon Mission Android Wear Battery Replacement
Cosa ti serve
  1. Nixon Mission Android Wear Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Remove 4 4.5mm Phillips head screws from back side of watch using PH00 Phillips head.
  2. Nixon Mission Android Wear Battery Replacement: passo 2, immagine 1 di 1
    • Remove the back plate of watch.
  3. Nixon Mission Android Wear Battery Replacement: passo 3, immagine 1 di 1
    • Unclip 5 latches from motherboard using a plastic spudger.
  4. Nixon Mission Android Wear Battery Replacement: passo 4, immagine 1 di 1
    • Remove the 2 3.0mm screws from motherboard using PH00 Phillips head.
  5. Nixon Mission Android Wear Battery Replacement: passo 5, immagine 1 di 1
    • Carefully remove motherboard & internal screen.
  6. Nixon Mission Android Wear Battery Replacement: passo 6, immagine 1 di 1
    • Remove from the motherboard the connector with the four cables.
    • Pull the cables upward and the motherboard downward as shown in the picture.
  7. Nixon Mission Android Wear Battery Replacement: passo 7, immagine 1 di 1
    • Carefully remove the battery from the watch.
Conclusione
Altre 6 persone hanno completato questa guida.
IUPUI, Team S3-G2, Harley Fall 2017 Membro di IUPUI, Team S3-G2, Harley Fall 2017
IUPUI-HARLEY-F17S3G2
3 Membri
3 Guide realizzate
18 Commenti
Hi, would you be able to advise where to purchase a replacement battery?
Simon Seow - Replica
same here, where to purchase a replacement battery ?
peter.erdogyaraki - Replica
Thank you for your tuto.
But now, where I can purchase a new battery?
Thank you
COUTURIER - Replica
Hi! Anyone knows where to buy a new battery?
cristian.carvelli - Replica
After an extensive search there doesn't seem to be any info out there about battery sizeā€¦..still
Jerry Jerry J - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 57
Tutti i Tempi: 6,440
