Salta al contenuto principale
Nissan Versa Note Media Display System Replacement
Cosa ti serve
  1. Nissan Versa Note Media Display System Replacement, Media Display System: passo 1, immagine 1 di 1
    • Ensure that the car is turned off.
  2. Nissan Versa Note Media Display System Replacement: passo 2, immagine 1 di 1
    • Pull on the switch for indoor/outdoor air to remove it.
  3. Nissan Versa Note Media Display System Replacement: passo 3, immagine 1 di 2 Nissan Versa Note Media Display System Replacement: passo 3, immagine 2 di 2
    • Use a spudger (or an old credit card) to gently pry the front panel away from the rest of the dash.
    • After wedging the parts apart you will see a gap.
  4. Nissan Versa Note Media Display System Replacement: passo 4, immagine 1 di 3 Nissan Versa Note Media Display System Replacement: passo 4, immagine 2 di 3 Nissan Versa Note Media Display System Replacement: passo 4, immagine 3 di 3
    • Using your fingers, start from the top of the panel and move down on either side to pry the panel open.
  5. Nissan Versa Note Media Display System Replacement: passo 5, immagine 1 di 2 Nissan Versa Note Media Display System Replacement: passo 5, immagine 2 di 2
    • Once the panel is free from the dash, flip it over to expose the cables connected to it.
  6. Nissan Versa Note Media Display System Replacement: passo 6, immagine 1 di 3 Nissan Versa Note Media Display System Replacement: passo 6, immagine 2 di 3 Nissan Versa Note Media Display System Replacement: passo 6, immagine 3 di 3
    • Remove the top cable by simply squeezing the end and pulling it out of its socket.
    • Use a spudger to push down on the tab of the bottom cable and remove it.
  7. Nissan Versa Note Media Display System Replacement: passo 7, immagine 1 di 3 Nissan Versa Note Media Display System Replacement: passo 7, immagine 2 di 3 Nissan Versa Note Media Display System Replacement: passo 7, immagine 3 di 3
    • The front panel is now completely free from the dash and can be set aside.
    • Using a Phillips #3 screwdriver, remove the two screws on either side of the media system.
  8. Nissan Versa Note Media Display System Replacement: passo 8, immagine 1 di 2 Nissan Versa Note Media Display System Replacement: passo 8, immagine 2 di 2
    • Carefully pull out the media system and turn it over so that the cables on its rear are visible.
    • Use your hands to pinch the tabs and gently pull out each cable.
  9. Nissan Versa Note Media Display System Replacement: passo 9, immagine 1 di 3 Nissan Versa Note Media Display System Replacement: passo 9, immagine 2 di 3 Nissan Versa Note Media Display System Replacement: passo 9, immagine 3 di 3
    • Now the media system is completely free from the car.
    • Using a T10 Torx screwdriver, unscrew the four screws on either side of the media system.
Conclusione
Altre 2 persone hanno completato questa guida.
Un commento
Muy ilustrativo y de muchá ayuda, gracias
Juanmanuel - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 40
Ultimi 30 Giorni: 71
Tutti i Tempi: 4,174
