Salta al contenuto principale
Nintendo Wii mini Motherboard Replacement
Cosa ti serve
  1. Nintendo Wii mini Motherboard Replacement, Unscrew the Bottom: passo 1, immagine 1 di 2 Nintendo Wii mini Motherboard Replacement, Unscrew the Bottom: passo 1, immagine 2 di 2
    • Remove the two rubber feet at the back of the console to reveal the hidden screws.
    • Remove the four 6mm Phillips #0 screws.
  2. Nintendo Wii mini Motherboard Replacement, Remove the Cover: passo 2, immagine 1 di 3 Nintendo Wii mini Motherboard Replacement, Remove the Cover: passo 2, immagine 2 di 3 Nintendo Wii mini Motherboard Replacement, Remove the Cover: passo 2, immagine 3 di 3
    • Turn the Wii mini right-side up. Then run a plastic opening tool around the middle edge of the console to loosen the top piece.
    • Gently lift the top piece of the console and set it aside.
  3. Nintendo Wii mini Motherboard Replacement, Unscrew the Fan: passo 3, immagine 1 di 2 Nintendo Wii mini Motherboard Replacement, Unscrew the Fan: passo 3, immagine 2 di 2
    • Turn the Wii mini around so that the back of the device is facing you.
    • Using a Phillips #0 Screwdriver, unscrew the two 6mm screws on either side of the fan piece.
    • You may need to use tweezers to pull out the screws once they are loosened.
  4. Nintendo Wii mini Motherboard Replacement, Detach the Fan Connector: passo 4, immagine 1 di 3 Nintendo Wii mini Motherboard Replacement, Detach the Fan Connector: passo 4, immagine 2 di 3 Nintendo Wii mini Motherboard Replacement, Detach the Fan Connector: passo 4, immagine 3 di 3
    • Using your fingers, gently pull the top of the pin connector straight up to detach the fan from the console.
    • Do not wiggle the connector or cable while removing. This may cause the connector to come loose
    • Remove the fan piece and set it aside.
  5. Nintendo Wii mini Motherboard Replacement, Power Board: passo 5, immagine 1 di 3 Nintendo Wii mini Motherboard Replacement, Power Board: passo 5, immagine 2 di 3 Nintendo Wii mini Motherboard Replacement, Power Board: passo 5, immagine 3 di 3
    • Using your fingers, slide out the blue ribbon cable from the the top of the power board.
    • Using a Phillips #0 Screwdriver, unscrew the two 4mm screws at the top and bottom of the power board.
  6. Nintendo Wii mini Motherboard Replacement: passo 6, immagine 1 di 2 Nintendo Wii mini Motherboard Replacement: passo 6, immagine 2 di 2
    • Using your fingers, gently pull the pin connector to disconnect the power board from the disc drive.
  7. Nintendo Wii mini Motherboard Replacement: passo 7, immagine 1 di 2 Nintendo Wii mini Motherboard Replacement: passo 7, immagine 2 di 2
    • Lift the power board from the console and set it aside.
  8. Nintendo Wii mini Motherboard Replacement, Disc Drive: passo 8, immagine 1 di 2 Nintendo Wii mini Motherboard Replacement, Disc Drive: passo 8, immagine 2 di 2
    • Using a Phillips #0 Screwdriver, unscrew the four 6mm screws.
  9. Nintendo Wii mini Motherboard Replacement: passo 9, immagine 1 di 2 Nintendo Wii mini Motherboard Replacement: passo 9, immagine 2 di 2
    • Lift the disc drive out of the console and set it aside.
  10. Nintendo Wii mini Motherboard Replacement, Unscrew the Tray: passo 10, immagine 1 di 1
    • Using a Phillips #0 Screwdriver, unscrew the 6 mm screw at the top of the black tray.
    There is actually two additional screws at the bottom of the tray
    Serhii Mukha - Replica
  11. Nintendo Wii mini Motherboard Replacement, Remove the Tray: passo 11, immagine 1 di 3 Nintendo Wii mini Motherboard Replacement, Remove the Tray: passo 11, immagine 2 di 3 Nintendo Wii mini Motherboard Replacement, Remove the Tray: passo 11, immagine 3 di 3
    • Using your fingers, pull the black plastic tray toward you to loosen it from the console.
    • Make sure the black square pieces are separated from the metal square pieces before trying to lift out the tray.
    • Once separated, lift the plastic tray out of the console and set it aside.
    • Trying to remove the tray before it is completely loosened may result in damage to the metal square pieces.
  12. Nintendo Wii mini Motherboard Replacement, Unscrew the Metal Casing: passo 12, immagine 1 di 2 Nintendo Wii mini Motherboard Replacement, Unscrew the Metal Casing: passo 12, immagine 2 di 2
    • Using a Phillips #0 screwdriver, remove the eleven 5 mm screws holding the silver metal plate to the console.
    • These screws are indicated by small arrows on the metal plate. (See Photo #2)
  13. Nintendo Wii mini Motherboard Replacement, Remove Metal Casing: passo 13, immagine 1 di 2 Nintendo Wii mini Motherboard Replacement, Remove Metal Casing: passo 13, immagine 2 di 2
    • Lift out the metal plate and set it aside.
  14. Nintendo Wii mini Motherboard Replacement, Remove Motherboard: passo 14, immagine 1 di 2 Nintendo Wii mini Motherboard Replacement, Remove Motherboard: passo 14, immagine 2 di 2
    • Lift out the motherboard and set it aside.
Conclusione
Altre 9 persone hanno completato questa guida.
UWT Liner: Group 5 Membro di UWT Liner: Group 5
Community
3 Membri
10 Guide realizzate
Un commento
Can you fit a Wii Motherboard inside this casing, and use the dvd drive, if so I have a few wiis with broken DVD drives I would like to repair and this would be a cheap solution.
Christopher Wortman - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 23
Ultimi 30 Giorni: 77
Tutti i Tempi: 4,796
