Salta al contenuto principale
Nintendo Wii mini Disc Drive Replacement
Cosa ti serve
  1. Nintendo Wii mini Disc Drive Replacement, Unscrew the Bottom: passo 1, immagine 1 di 2 Nintendo Wii mini Disc Drive Replacement, Unscrew the Bottom: passo 1, immagine 2 di 2
    • Remove the two rubber feet at the back of the console to reveal the hidden screws.
    • Remove the four 6mm Phillips #0 screws.
  2. Nintendo Wii mini Disc Drive Replacement, Remove the Cover: passo 2, immagine 1 di 3 Nintendo Wii mini Disc Drive Replacement, Remove the Cover: passo 2, immagine 2 di 3 Nintendo Wii mini Disc Drive Replacement, Remove the Cover: passo 2, immagine 3 di 3
    • Turn the Wii mini right-side up. Then run a plastic opening tool around the middle edge of the console to loosen the top piece.
    • Gently lift the top piece of the console and set it aside.
  3. Nintendo Wii mini Disc Drive Replacement, Unscrew the Fan: passo 3, immagine 1 di 2 Nintendo Wii mini Disc Drive Replacement, Unscrew the Fan: passo 3, immagine 2 di 2
    • Turn the Wii mini around so that the back of the device is facing you.
    • Using a Phillips #0 Screwdriver, unscrew the two 6mm screws on either side of the fan piece.
    • You may need to use tweezers to pull out the screws once they are loosened.
  4. Nintendo Wii mini Disc Drive Replacement, Detach the Fan Connector: passo 4, immagine 1 di 3 Nintendo Wii mini Disc Drive Replacement, Detach the Fan Connector: passo 4, immagine 2 di 3 Nintendo Wii mini Disc Drive Replacement, Detach the Fan Connector: passo 4, immagine 3 di 3
    • Using your fingers, gently pull the top of the pin connector straight up to detach the fan from the console.
    • Do not wiggle the connector or cable while removing. This may cause the connector to come loose
    • Remove the fan piece and set it aside.
  5. Nintendo Wii mini Disc Drive Replacement, Power Board: passo 5, immagine 1 di 3 Nintendo Wii mini Disc Drive Replacement, Power Board: passo 5, immagine 2 di 3 Nintendo Wii mini Disc Drive Replacement, Power Board: passo 5, immagine 3 di 3
    • Using your fingers, slide out the blue ribbon cable from the the top of the power board.
    • Using a Phillips #0 Screwdriver, unscrew the two 4mm screws at the top and bottom of the power board.
  6. Nintendo Wii mini Disc Drive Replacement: passo 6, immagine 1 di 2 Nintendo Wii mini Disc Drive Replacement: passo 6, immagine 2 di 2
    • Using your fingers, gently pull the pin connector to disconnect the power board from the disc drive.
  7. Nintendo Wii mini Disc Drive Replacement: passo 7, immagine 1 di 2 Nintendo Wii mini Disc Drive Replacement: passo 7, immagine 2 di 2
    • Lift the power board from the console and set it aside.
  8. Nintendo Wii mini Disc Drive Replacement, Disc Drive: passo 8, immagine 1 di 2 Nintendo Wii mini Disc Drive Replacement, Disc Drive: passo 8, immagine 2 di 2
    • Using a Phillips #0 Screwdriver, unscrew the four 6mm screws.
  9. Nintendo Wii mini Disc Drive Replacement: passo 9, immagine 1 di 2 Nintendo Wii mini Disc Drive Replacement: passo 9, immagine 2 di 2
    • Lift the disc drive out of the console and set it aside.
Conclusione
Altre 3 persone hanno completato questa guida.
UWT Liner: Group 5 Membro di UWT Liner: Group 5
Community
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 56
Tutti i Tempi: 4,304
