Salta al contenuto principale
Nintendo Wii U Wireless Module Replacement
Cosa ti serve
  1. Nintendo Wii U Wireless Module Replacement, Console Outer Case: passo 1, immagine 1 di 1
    • With the bottom of the console facing up, remove the following 6 screws hidden underneath the white square stickers:
    • Three 5.1mm Phillips #000 screws
    • Two 6.1mm Tri-wing Y0 screws
    • One 13.2mm Tri-wing Y1 screw
  2. Nintendo Wii U Wireless Module Replacement: passo 2, immagine 1 di 1
    • Rotate the console 180 degrees so that the exhaust vents are facing you.
    • Remove the two 7.1mm Phillips #00 screws.
  3. Nintendo Wii U Wireless Module Replacement: passo 3, immagine 1 di 2 Nintendo Wii U Wireless Module Replacement: passo 3, immagine 2 di 2
    • On the side opposite of the exhaust vents, slide the cover faceplate towards the back of the console and pull upwards to release it.
  4. Nintendo Wii U Wireless Module Replacement: passo 4, immagine 1 di 1
    • On the bottom of the console beneath the previously removed faceplate, remove the three 13.2mm Tri-wing Y1 screws.
  5. Nintendo Wii U Wireless Module Replacement: passo 5, immagine 1 di 3 Nintendo Wii U Wireless Module Replacement: passo 5, immagine 2 di 3 Nintendo Wii U Wireless Module Replacement: passo 5, immagine 3 di 3
    • On the back of the console, lift up and release the main top cover.
  6. Nintendo Wii U Wireless Module Replacement, Front Faceplate: passo 6, immagine 1 di 2 Nintendo Wii U Wireless Module Replacement, Front Faceplate: passo 6, immagine 2 di 2
    • Rotate the device so that the front plate is facing you.
    • On each side of the console, remove the 3.5mm Phillips #0 screw connecting the DVD drive to the faceplate.
  7. Nintendo Wii U Wireless Module Replacement: passo 7, immagine 1 di 1
    • Rotate the device so that the front plate is on the right side and the ribbon cable is visible.
    • The ribbon cable is connected to the system by a latch which holds in the blue tab. Flip this latch up to unlock it.
    • Lift up on the blue tab to release the ribbon cable.
  8. Nintendo Wii U Wireless Module Replacement: passo 8, immagine 1 di 1
    • Remove the front faceplate.
  9. Nintendo Wii U Wireless Module Replacement, DVD Drive: passo 9, immagine 1 di 1
    • On each side of the DVD drive, remove the two 4.6mm Phillips #0 mounting screws.
  10. Nintendo Wii U Wireless Module Replacement: passo 10, immagine 1 di 2 Nintendo Wii U Wireless Module Replacement: passo 10, immagine 2 di 2
    • Rotate the device so that the disc drive slot is visible.
    • A ribbon cable is attached to the bottom right side of the disc drive. The ribbon cable can rip if it isn't removed properly.
    • Lift the disc drive out of the mount and turn over to the right so it lies like a book.
    • Use a spudger to release the ribbon cable.
  11. Nintendo Wii U Wireless Module Replacement: passo 11, immagine 1 di 1
    • Remove the disc drive.
  12. Nintendo Wii U Wireless Module Replacement, Motherboard: passo 12, immagine 1 di 3 Nintendo Wii U Wireless Module Replacement, Motherboard: passo 12, immagine 2 di 3 Nintendo Wii U Wireless Module Replacement, Motherboard: passo 12, immagine 3 di 3
    • Remove the black plastic shielding by unscrewing connecting screws with a Phillip's Head screwdriver.
    • You will have to carefully adjust the antenna cables out of the way in order to proceed comfortably.
  13. Nintendo Wii U Wireless Module Replacement: passo 13, immagine 1 di 3 Nintendo Wii U Wireless Module Replacement: passo 13, immagine 2 di 3 Nintendo Wii U Wireless Module Replacement: passo 13, immagine 3 di 3
    • The metal cap does not require unscrewing and should lift up with ease.
    • Unscrew all the screws that outline the perimeter of the board using a Phillips Head (PH1) screwdriver.
    • Remove the silver shielding plate once all screws are removed. Be careful when pulling it under the affixed antenna cables.
  14. Nintendo Wii U Wireless Module Replacement: passo 14, immagine 1 di 2 Nintendo Wii U Wireless Module Replacement: passo 14, immagine 2 di 2
    • At this point, the motherboard should easily separate from the lower tray.
  15. Nintendo Wii U Wireless Module Replacement, Wireless 5ghz Module: passo 15, immagine 1 di 3 Nintendo Wii U Wireless Module Replacement, Wireless 5ghz Module: passo 15, immagine 2 di 3 Nintendo Wii U Wireless Module Replacement, Wireless 5ghz Module: passo 15, immagine 3 di 3
    • Flip the motherboard over to view the underside where the Wii U's wireless modules are located. The Bluetooth module is circled in red.
    • This module is affixed with strong adhesive, so in order to remove it you will need to wiggle the module with slight force for a couple of minutes.
Conclusione
Altre 4 persone hanno completato questa guida.
USF Tampa, Team 1-2, Leahy Spring 2016 Membro di USF Tampa, Team 1-2, Leahy Spring 2016
USFT-LEAHY-S16S1G2
3 Membri
12 Guide realizzate
14 Commenti
Where would be able to buy this replacement part? Anyone know?
Salvador Mora - Replica
I found on aliexpress
Rodrigo Mafort -
I actually just bought a secondary Wii U just to be sure I don't get a cheap part, it was like $65 with a credit on eBay
Salvador Mora -
Which one of these is for the module for control pad?:
Broadcom BCM43237KMLG Wireless LAN module
Broadcom BCM43362KUB6 802.11n Wireless Module—the same one used in the Roku 2 XS
Broadcom BCM20702 Bluetooth 4.0
Dan - Replica
bcm43362kub6
Rodrigo Mafort -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 22
Ultimi 30 Giorni: 106
Tutti i Tempi: 11,333
