Salta al contenuto principale
Nintendo Wii U GamePad Directional Pad Buttons Replacement
Cosa ti serve
  1. Nintendo Wii U GamePad Directional Pad Buttons Replacement, Back Panel: passo 1, immagine 1 di 3 Nintendo Wii U GamePad Directional Pad Buttons Replacement, Back Panel: passo 1, immagine 2 di 3 Nintendo Wii U GamePad Directional Pad Buttons Replacement, Back Panel: passo 1, immagine 3 di 3
    • Remove the ten 8.9mm Tri-wing Y1 screws hidden underneath square stickers.
    • Lift up the back plate.
    • The back plate is still connected by a cable to the motherboard.
  2. Nintendo Wii U GamePad Directional Pad Buttons Replacement: passo 2, immagine 1 di 2 Nintendo Wii U GamePad Directional Pad Buttons Replacement: passo 2, immagine 2 di 2
    • Unplug the connector that connects the back plate to the motherboard.
    • Remove the back panel.
  3. Nintendo Wii U GamePad Directional Pad Buttons Replacement, Analog Stick: passo 3, immagine 1 di 2 Nintendo Wii U GamePad Directional Pad Buttons Replacement, Analog Stick: passo 3, immagine 2 di 2
    • Take out the left and right shoulder buttons in the upper corners.
    • Remove the ZR and ZL trigger buttons by lifting up and sliding outward.
  4. Nintendo Wii U GamePad Directional Pad Buttons Replacement: passo 4, immagine 1 di 2 Nintendo Wii U GamePad Directional Pad Buttons Replacement: passo 4, immagine 2 di 2
    • Remove the top rubber cover by pulling it off of its mounts to access one of the mounting screws.
    • Remove the four 5.2mm Phillips #0 screws.
  5. Nintendo Wii U GamePad Directional Pad Buttons Replacement: passo 5, immagine 1 di 2 Nintendo Wii U GamePad Directional Pad Buttons Replacement: passo 5, immagine 2 di 2
    • Use a spudger to lift the tab which releases the blue ribbon cable.
    • Remove the analog stick and button cover.
  6. Nintendo Wii U GamePad Directional Pad Buttons Replacement: passo 6, immagine 1 di 1
    • Use your thumb and push the connector towards the rightmost edge to disconnect the analog stick cable connector.
  7. Nintendo Wii U GamePad Directional Pad Buttons Replacement: passo 7, immagine 1 di 2 Nintendo Wii U GamePad Directional Pad Buttons Replacement: passo 7, immagine 2 di 2
    • Remove the two 9.0mm Tri-wing Y0 screws.
    • Lift out the analog stick.
  8. Nintendo Wii U GamePad Directional Pad Buttons Replacement, Directional Pad Buttons: passo 8, immagine 1 di 2 Nintendo Wii U GamePad Directional Pad Buttons Replacement, Directional Pad Buttons: passo 8, immagine 2 di 2
    • Lift up and remove the rubber cover for the directional pad.
    • Remove the directional pad buttons.
Conclusione
Altre 11 persone hanno completato questa guida.
Kim Arre
Membro da: 01/11/13
5.247 Reputazione
8 Guide realizzate
Cal Poly, Team 17-20, Forte Winter 2013 Membro di Cal Poly, Team 17-20, Forte Winter 2013
CPSU-FORTE-W13S17G20
5 Membri
40 Guide realizzate
1Commento della guida
Where can you find the blue ribbon mentioned in step 5, for the buttons at?
Eric - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 36
Ultimi 30 Giorni: 135
Tutti i Tempi: 21,606
