Introduzione
Installare la scheda madre di un telecomando Wii richiede la rimozione della cover frontale e permette l’accesso al pulsante B.
Cosa ti serve
Gira il Wii Remote in modo tale da avere la copertura della batteria verso di te.
Spingi verso l'alto la clip inferiore.
Rimuovi la copertura della batteria.
Con l'estremità piatta di uno spudger, applica un po' di pressione sulle clip presenti sul lato sinistro del controller.
Apri la parte frontale come un libro.
Mine is not opening like a book? What do I do?
It stops short of explaining replacing rechargeable battery. Unless you’re referring to the AA’s which don’t involve removing cover
Usando la porta connettore, solleva gentilmente la scheda madre di 2 cm dalla base.
Per rimontare il tuo dispositivo, segui queste istruzioni al contrario.
Altre 26 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
7 Commenti
This is useless because you can't just buy a motherboard. May as well buy a new remote for $20
Where can i buy a brand new and original (not fake of course) wii remote for $20?
You can buy a first party Wii remote plus for under $50 at Walmart, best buy, or online on Amazon or on Nintendos website
What is the dimension is the motherboard? I want to make a custom motherboard for the housing but I haven't managed to get int the wiimote yet as I am waiting for my tri screwdriver
Just adding a comment to dispute the above suggestion that “this is useless”. I used this guide to help repair a damaged Wii Controller which had had some battery leakage onto the mainboard. I was able to open the controller, clean up (using vinegar and water) the battery corrosion and re-assemble the controller. It works fine again now and I used this guide to find out that there are plastic clips holding the case together.
I can't sync my Wii balance board. and remote at the same time. when the Wii remotes sync the balance board goes out and vice versa
