Salta al contenuto principale
Nintendo Wii Fan Replacement
Cosa ti serve
  1. Nintendo Wii Fan Replacement, Faceplate: passo 1, immagine 1 di 2 Nintendo Wii Fan Replacement, Faceplate: passo 1, immagine 2 di 2
    • Use a metal spudger to remove the white plastic screw covers stuck to the lower case near the front of the Wii.
  2. Nintendo Wii Fan Replacement: passo 2, immagine 1 di 1
    • Remove the two 8.3 mm Tri-Point screws hidden under the covers you just removed.
  3. Nintendo Wii Fan Replacement: passo 3, immagine 1 di 1
    • Remove the single 5.9 mm Phillips screw under the controller port door nearest the faceplate.
  4. Nintendo Wii Fan Replacement: passo 4, immagine 1 di 1
    • Use a metal spudger to remove the rubber foot stuck to the side of the Wii near the DVD drive opening.
  5. Nintendo Wii Fan Replacement: passo 5, immagine 1 di 1
    • Remove the single 5.9 mm Phillips screw hidden under the foot you just removed.
  6. Nintendo Wii Fan Replacement: passo 6, immagine 1 di 2 Nintendo Wii Fan Replacement: passo 6, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Carefully pull the faceplate away from the front of the Wii.
    • Use a pair of tweezers to disconnect the LED cable's plastic connector from the motherboard.
    • Remove the faceplate.
  7. Nintendo Wii Fan Replacement, Outer Case: passo 7, immagine 1 di 3 Nintendo Wii Fan Replacement, Outer Case: passo 7, immagine 2 di 3 Nintendo Wii Fan Replacement, Outer Case: passo 7, immagine 3 di 3
    • Open the controller port cover until it is perpendicular to the black controller port bezel.
    • Pull the controller port cover straight up to release it from the outer case.
    • Repeat this procedure for the memory card port cover.
  8. Nintendo Wii Fan Replacement: passo 8, immagine 1 di 2 Nintendo Wii Fan Replacement: passo 8, immagine 2 di 2
    • Remove the two remaining 4.1 mm Phillips screws along the top edge of the black plastic controller port bezel.
    • Lift the bezel from the long edge furthest away from the controller ports and remove it from the Wii.
  9. Nintendo Wii Fan Replacement: passo 9, immagine 1 di 1
    • Remove the two 5 mm Phillips screws above the controller ports.
  10. Nintendo Wii Fan Replacement: passo 10, immagine 1 di 1
    • Use a metal spudger to remove the three highlighted screw covers stuck to the side of the Wii.
  11. Nintendo Wii Fan Replacement: passo 11, immagine 1 di 1
    • Remove the following screws:
    • Two 5 mm Phillips screws
    • One 8.2 mm Tri-Point screw
  12. Nintendo Wii Fan Replacement: passo 12, immagine 1 di 1
    • Use a metal spudger to remove the two rubber feet stuck to the bottom face of the Wii near the rear ports.
  13. Nintendo Wii Fan Replacement: passo 13, immagine 1 di 1
    iFixit Precision 4 mm Screwdriver Bit
    $2.99
    • Remove the two 8.2 mm Tri-Point screws hidden under the feet you just removed.
    • You may use a 4 mm hex nut driver to extend your bit into the recesses and reach the screws.
  14. Nintendo Wii Fan Replacement: passo 14, immagine 1 di 1
    • Lift the outer case straight up off the body of the Wii.
  15. Nintendo Wii Fan Replacement, Fan: passo 15, immagine 1 di 1
    • Grab the fan connector with a pair of tweezers and lift it straight up and out of its socket on the motherboard.
    • Be sure your tweezers are clamped down on the fan connector, not the socket attached to the motherboard.
  16. Nintendo Wii Fan Replacement: passo 16, immagine 1 di 1
    • Remove the two 10 mm Phillips screws securing the fan to the fan shroud.
  17. Nintendo Wii Fan Replacement: passo 17, immagine 1 di 1
    • Remove the fan from the Wii.
Conclusione
Altre 34 persone hanno completato questa guida.
9Commenti sulla guida
Awesome guide, just replaced faulty fan unit in my 9 year old wii. Should hopefully keep it going for another 9 years :)
Finlay Macrae - Replica
Super easy and great instructions! I feel a little guilty that my Wii sat in the garage for 4 years! Now it'll be a great birthday present for my 2 boys.
e_gayheart - Replica
Does anyone have a diagram for the Wii’s airflow? I’m looking to install a booster fan at the bottom to help blow air in but I want to make sure it is effective.
Jessica Parnelli Fawkes - Replica
nice¡¡¡¡¡¡¡¡¡¡¡¡¡¡
RIGO NOLASCO - Replica
Thanks! Wii Quarantine’n in 2021!
Daniel Thomas - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 16
Ultimi 7 Giorni: 106
Ultimi 30 Giorni: 522
Tutti i Tempi: 47,640
