Salta al contenuto principale
Nintendo WaveBird Wireless Controller Front Panel Replacement
Cosa ti serve
  1. Nintendo WaveBird Wireless Controller Front Panel Replacement, Batteries: passo 1, immagine 1 di 2 Nintendo WaveBird Wireless Controller Front Panel Replacement, Batteries: passo 1, immagine 2 di 2
    • Pull down on the battery cover release lever and pull back to remove the cover.
  2. Nintendo WaveBird Wireless Controller Front Panel Replacement: passo 2, immagine 1 di 1
    • Remove both batteries from the device.
  3. Nintendo WaveBird Wireless Controller Front Panel Replacement, Front Panel: passo 3, immagine 1 di 2 Nintendo WaveBird Wireless Controller Front Panel Replacement, Front Panel: passo 3, immagine 2 di 2
    • Remove the eight 9 mm screws from the back panel using the Tri-point Y1 screwdriver.
    • During reassembly, firmly hold the panels of the controller together while replacing the screws so the panels do not separate.
  4. Nintendo WaveBird Wireless Controller Front Panel Replacement: passo 4, immagine 1 di 2 Nintendo WaveBird Wireless Controller Front Panel Replacement: passo 4, immagine 2 di 2
    • Carefully turn over the controller and place it on a flat surface.
    • Slowly separate the top panel from the bottom panel.
    • The buttons are loose and may fall off the motherboard.
    • Once separated, set aside the top panel.
    • During reassembly, make sure the front panel lines up with the buttons so they slide back into place.
Conclusione
Altre 3 persone hanno completato questa guida.
JT Gryder
Membro da: 04/12/13
114 Reputazione
1 Guida realizzata
Cal Poly, Team 10-40, Amido Spring 2013 Membro di Cal Poly, Team 10-40, Amido Spring 2013
CPSU-AMIDO-S13S10G40
4 Membri
37 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 12
Tutti i Tempi: 1,605
