Introduzione
This guide aims to walk you through the steps required in replacing the face buttons on the right Joy-Con for the Nintendo Switch. This repair is slightly more difficult than the left Joy-Con as there are more components built into the right than there are in the left. Additional components to be aware of include the Infrared Sensor, Bluetooth Antenna, and NFC Antenna.
Cosa ti serve
Use a Tri-wing Y00 screwdriver to remove the four 5mm screws holding the back panel in place.
Insert the end of a plastic opening pick between the IR sensor and the back panel.
Run the tool along the edge, gently applying pressure downwards, to release the back panel from the clips holding it in place.
Open the Joy-Con as if it was a book, rotating around the black guide rail.
To reassemble your device, follow these instructions in reverse order. Be sure not to screw the motherboard in too tight as this may affect the responsiveness of the buttons. Always apply even pressure to screws when reinstalling the components; one side should not be tighter than the other.
Altre 37 persone hanno completato questa guida.
7 Commenti
How do I take the black inner part of the home button out of it’s holding thing?
I need help with this as well. In the last picture you can see how the home button sits in a clear plastic ring and I cant get it out of there to place my new colorful home button
Doesn’t include how to change the trigger button…. :/
Super guide as always. Succesfully replaced the sl and sr buttons. Thanks!!
