Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
Follow this guide to replace a cracked or damaged rear panel on the Nintendo Switch.
Note: This guide, and the part we sell, are compatible with the original Nintendo Switch model released in 2017, as well as the newer refreshed model released in 2019 (model numbers HAC-001 and HAC-001(-01), respectively).
  1. Before you begin this repair, make sure the device is completely powered off. Press and hold down the small round button on the back of the Joy Con controller. While you hold down the button, slide  the controller upward.
    • Before you begin this repair, make sure the device is completely powered off.
    • Press and hold down the small round button on the back of the Joy Con controller.
    • While you hold down the button, slide the controller upward.
  2. Continue sliding the controller upward until it's completely removed from the console. Repeat this same process for the other controller. Repeat this same process for the other controller.
    • Continue sliding the controller upward until it's completely removed from the console.
    • Repeat this same process for the other controller.
    • Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the rear panel.
  3. Use a JIS 000 screwdriver to remove the following screws securing the rear panel: One 2.5 mm-long screw on the top edge of the device
    • Use a JIS 000 screwdriver to remove the following screws securing the rear panel:
    • One 2.5 mm-long screw on the top edge of the device
    • Two 2.5 mm-long screws on the bottom edge of the device
  4. Use a JIS 000 screwdriver to remove the two 3.8 mm center screws on the sides of the device (one on each side). Use a JIS 000 screwdriver to remove the two 3.8 mm center screws on the sides of the device (one on each side).
    • Use a JIS 000 screwdriver to remove the two 3.8 mm center screws on the sides of the device (one on each side).
  5. Use your finger to flip up the kickstand on the back of the device. If there's a microSD card in the microSD card slot, remove it now before you continue to the next step.
    • Use your finger to flip up the kickstand on the back of the device.
    • If there's a microSD card in the microSD card slot, remove it now before you continue to the next step.
  6. Use a JIS 000 screwdriver to remove the 1.6 mm screw in the kickstand well.
    • Use a JIS 000 screwdriver to remove the 1.6 mm screw in the kickstand well.
  7. Lift the rear panel up from the bottom of the device and remove it. Lift the rear panel up from the bottom of the device and remove it. Lift the rear panel up from the bottom of the device and remove it.
    • Lift the rear panel up from the bottom of the device and remove it.
Conclusione
Compare your new replacement part to the original part. You may need to transfer remaining components from the new part before installing.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch Answers community for help.
Altre 40 persone hanno completato questa guida.
Craig Lloyd
Membro da: 10/02/2016
16.213 Reputazione
80 Guide realizzate
iFixit Membro di iFixit
Community
133 Membri
14.596 Guide realizzate
Excellent and concise guide.
The new panel doesn’t come with the sticky grille pieces x 2 on the bottom. Is it supposed to be a straight transfer between the old and the new?
Sal jUNK - Replica
Just did this replacement and there are a few things to keep in mind that this review does not mention. There are x2 square foam pieces that can be transferred to the new panel located at the bottom backside of the old. Also, the game cartridge shield hardware and the kickstand holder hardware have to be taken off the back of the old panel and transferred to the new panel. The kickstand has 2 Phillips #000 screws and the game cartridge shield has 1 Phillips #000 screw
Ryan Talbert - Replica
How do you transfer the foam pieces? Use some heat to loosen their adhesive and then remove them and transfer over the new backplate?
John - Replica
Is the casing the same between the HAC model and the HAD model? This guide doesn’t specify
Julian Webb - Replica
I am using iFixit Pro tool kit. What to do if one of the 000 screw’s cap appears to be stripped off? How to extract it if perchance?
Dr.Genuks - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 59
Ultimi 7 Giorni: 356
Ultimi 30 Giorni: 1,586
Tutti i Tempi: 28,798
