Introduzione
Follow this guide to replace a damaged or faulty microSD card reader on your Nintendo Switch game console.
The Switch uses JIS screws, but you can use a Phillips screwdriver in a pinch. Be very careful not to strip the screws. iFixit's Phillips bits are designed to be cross-compatible with JIS-style screws.
WARNING: The battery cannot be disconnected during this repair, so make sure to only use ESD-safe tools and be extra careful when using any metal tools. Not doing so could short a connection and damage the device.
Note: This guide, and the part we sell, are compatible with the original Nintendo Switch model released in 2017, as well as the newer refreshed model released in 2019 (model numbers HAC-001 and HAC-001(-01), respectively).
Cosa ti serve
Press and hold down the small round button on the back of the Joy Con controller.
While you hold down the button, slide the controller upward.
Continue sliding the Joy Con upward until it's completely removed from the console.
Attrezzo utilizzato in questo passaggio:Magnetic Project Mat$19.95
Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the rear panel.
Use a JIS 000 driver or an official iFixit PH 000 driver to remove the following screws securing the rear panel:
One 2.5 mm-long screw on the top edge of the device
Two 2.5 mm-long screws on the bottom edge of the device
Use a JIS 000 screwdriver or an official iFixit PH 000 driver to remove the 3.1 mm screw securing the microSD card reader to the device.
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch Answers community for help.
Altre 138 persone hanno completato questa guida.
48 Commenti
My SD reader never worked.
Used this guide to find that it was never seated correctly. Reseated and now works perfectly. THANK YOU!
My console won’t boot if I have an SD card inserted after reseating it. What should I do?
Easy guide, fixed my problem. Changed the SD card reader cause I was abusing of it by putting SD in and out constantly.
Some one can help me, when I tried to put the connector again I damage the fpc connector of the motherboard so I try to find out again can any one know the kind of model of this connector I really appreciate the help
Best regards
