Salta al contenuto principale
Nintendo Super Famicom SHVC-001 Controller Port Board Replacement
Cosa ti serve
  1. Nintendo Super Famicom SHVC-001 Controller Port Board Replacement, Upper Case: passo 1, immagine 1 di 1
    • Remove the six 13.5 mm screws on the lower case with a 4.5 mm Gamebit screwdriver.
  2. Nintendo Super Famicom SHVC-001 Controller Port Board Replacement: passo 2, immagine 1 di 2 Nintendo Super Famicom SHVC-001 Controller Port Board Replacement: passo 2, immagine 2 di 2
    • Flip the Famicom over and set it down.
    • Lift off the upper case.
  3. Nintendo Super Famicom SHVC-001 Controller Port Board Replacement, Controller Port Board: passo 3, immagine 1 di 2 Nintendo Super Famicom SHVC-001 Controller Port Board Replacement, Controller Port Board: passo 3, immagine 2 di 2
    • Carefully disconnect the ribbon cable that is attached to the controller board and the main board.
  4. Nintendo Super Famicom SHVC-001 Controller Port Board Replacement: passo 4, immagine 1 di 1
    • Lift the controller port board directly up and out of the chassis.
    • If your new controller port board does not come with a ribbon cable, you will also need to replace that.
  5. Nintendo Super Famicom SHVC-001 Controller Port Board Replacement: passo 5, immagine 1 di 3 Nintendo Super Famicom SHVC-001 Controller Port Board Replacement: passo 5, immagine 2 di 3 Nintendo Super Famicom SHVC-001 Controller Port Board Replacement: passo 5, immagine 3 di 3
    • The next bullet demonstrates how to replace your ribbon cable.
    • Disconnect and remove the old cable and replace it with a new 1.25 mm ribbon cable.
Conclusione
Un commento
The B button only works but the rest of the controller is not pressing. Can you help?
Maximus Sampaio Costa - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 26
Tutti i Tempi: 254
