Salta al contenuto principale
Nintendo NES Advantage Circuit Board Replacement
Cosa ti serve
  1. Nintendo NES Advantage Circuit Board Replacement, Back Panel: passo 1, immagine 1 di 1
    • Remove the four sticky pads from the bottom of the device.
    • If the pads are stuck, use a spudger to remove them.
  2. Nintendo NES Advantage Circuit Board Replacement: passo 2, immagine 1 di 2 Nintendo NES Advantage Circuit Board Replacement: passo 2, immagine 2 di 2
    • Remove the six 8 mm screws from the bottom of the device with a Phillips #0 screwdriver.
    • Use your hands to pull the back panel away from the controller.
  3. Nintendo NES Advantage Circuit Board Replacement, Circuit Board: passo 3, immagine 1 di 2 Nintendo NES Advantage Circuit Board Replacement, Circuit Board: passo 3, immagine 2 di 2
    • Remove the three 14 mm screws from the gray cross with a Phillips #0 screwdriver.
    • Lift the gray component away from the device.
  4. Nintendo NES Advantage Circuit Board Replacement: passo 4, immagine 1 di 1
    • Lift up the black wire and move it to the side.
  5. Nintendo NES Advantage Circuit Board Replacement: passo 5, immagine 1 di 3 Nintendo NES Advantage Circuit Board Replacement: passo 5, immagine 2 di 3 Nintendo NES Advantage Circuit Board Replacement: passo 5, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Remove the two silver knobs on the front of the device.
    • Unscrew the two silver nuts using a flathead screwdriver.
    • Remove each silver nut and silver washer using a pair of tweezers.
  6. Nintendo NES Advantage Circuit Board Replacement: passo 6, immagine 1 di 2 Nintendo NES Advantage Circuit Board Replacement: passo 6, immagine 2 di 2
    • Remove the remaining three 8 mm screws on the circuit board with a Phillips #0 screwdriver.
    • Remove the silver bracket from the top of the circuit board.
  7. Nintendo NES Advantage Circuit Board Replacement: passo 7, immagine 1 di 1
    • Remove the circuit board from the controller.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 35
Tutti i Tempi: 419
