Introduzione
Removing the top case will allow you access to the GameCube's internal parts.
Strumenti
Parti
Nessuna parte specificata.
Turn over the Gamecube so that the bottom side is facing up.
Locate the four screws (circled in red) on each corner of the device. Then, use a 4.5 mm Gamebit screwdriver to remove all four screws.
With the bottom side of the GameCube facing upward and the screws removed, carefully pull the outer shell of the unit away from the top half. Then place the inside of the unit facing up.
This can also be done whilst being in the normal upright position after all 4 of the 4.5mm Gamebit screws have been removed. Pull the top of the shell directly upwards and it should slide off easily.
Less chance of snagging any wires or parts.
Altre 7 persone hanno completato questa guida.
Un commento
Can you do a more in-depth version of the top cover? I had to clean each piece and need help figuring out where all the pieces go. Thanks
