Introduzione
Removing the top case will allow you access to the GameCube's internal parts.
Cosa ti serve
Turn over the Gamecube so that the bottom side is facing up.
Use the 4.5 mm Gamebit screwdriver to remove all four screws.
Altre 13 persone hanno completato questa guida.
Un commento
Can you do a more in-depth version of the top cover? I had to clean each piece and need help figuring out where all the pieces go. Thanks
